: o2 sensor problem
bobbos21
06-30-13, 11:19 PM
long story short I had an o2 sensor on my 08 escalade go bad, I replaced it and now I am getting a p1175 code. I replaced the sensor with an aftermarket one and not a stock sensor. Could it be the aftermarket sensor is not registering as fast as the stock therefor causing the code? I am wondering if replacing the other upstream sensor with the same sensor would solve this issue.
SpyShops NY
06-30-13, 11:39 PM
I do know you have to replace both, doesnt matter if stock or not, than disconnect the battery for 5 min and reconnect.
bobbos21
06-30-13, 11:41 PM
just the upstream or the downstream as well?
SpyShops NY
06-30-13, 11:45 PM
Yes both, autozone says to do that. Did you buy the bosch.
bobbos21
06-30-13, 11:49 PM
Yes, good to know. Thanks for the info I really appreciate it
