: DIY: How to upgrade your 2010-2012 SRX Side Vents to the new 2013 style
davedogcaddy
06-30-13, 09:09 PM
The original discussion of this topic had gotten quite lengthy, so now that I have completed this mod I decided to compile everything into a (hopefully) more organized post. The original thread can be found here: http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/310402-finally-snagged-2013-my-style-lower.html
(http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/310402-finally-snagged-2013-my-style-lower.html)
In this DIY we'll cover something that (as far as I can tell) hasn't been done yet; upgrading the side vents on your 2010-2012 SRX to the updated 2013 style. Please note that my SRX is a 2010 MY, so while I would assume these instructions will work fine on the 2011 & 2012 we'll have to wait and see once some of those owners attempt this. This mod is not for the faint of heart. While it's not the hardest mod I've seen, it was WAY more involved than I originally suspected. PLEASE, realize this comes with risks, and I assume no responsibility if you screw something up. We will be tying into factory wiring harnesses, and doing some minor body work, so if something isn't done right you could really mess up your ride.
Let's begin with what you will need. First you will need to decide if you want the original factory all-chrome 2013 vents, or the dual-tone black/chrome accessory ones. I chose the originals. Here are the part numbers:
-2013 Original Factory Chrome vent (left): 22966564
-2013 Original Factory Chrome vent (right): 22966563
-2013 SRX Black/Chrome accessory vents (right/left set): 22844649
Chris at RippyAutomotive is your friend here. His prices were WAY better than what I could find anywhere else (even with shipping). List on the original vents was $188.55 each, his price was $141.41 each. List on the accessory version is $425 for the set, his price was $371.88. Plus he's VERY helpful - I could have NEVER completed this mod without the schematics he sent.
One specialty item you will need is two computer motherboard headers. These are the connectors that plug into to pins on a computer motherboard from the front panel LED/switches, or the front panel USB. You are looking for the 5x2 arrangement (very common). You can find them on eBay (search for USB header), or drop buy your local computer service shop and they may even give you some from a junk tower. This is your key to easily making a plug for the new vents since this part is not available yet for purchase.
Computer motherboard header (unmodified):
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-5MGFFnm/0/S/DSC00675-S.jpg
Other items you will need :
-wire (I bought a 40ft roll of 18 gauge black wire at AutoZone, used about half of it)
-heat shrink tube (they an assorted set at AutoZone in a really nice tackle-type box for $10
-crimp-on wire splice connectors (the red ones)
-electrical tape
Let's start! We'll begin by removing the original vents. The vents are held in place by two plastic clips.
(back of original vent - the orange things are the clips)
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-k86FKZW/1/L/005-L.jpg
They are removed by squeezing plastic clips, and simply pulling the vent off. The trick is getting to said clips. First cut the steering wheel all the way to left or right (depending on what side you are working on. Now remove the two lower screws along the outer edge of the wheel liner, next to the vent. You will also want to remove one plastic push clip at the top of the wheel liner. Pull back the wheel liner, reach your hand/arm inside the car and feel for the two plastic clips.
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-fCcrfFc/1/L/DSC00682-L.jpg
There will be one at the top, and one at the bottom. Pull the vent loose, and disconnect the electrical plug. Leave the plug hanging out the hole. We'll need that later. The passenger side is a breeze. Once you get to the driver's side, take a moment to appreciate the creative engineering that went into the design of the shape windshield washer fluid reservoir....because you will be cursing those engineers in a moment. Where the passenger side was roomy and easy to work with - this side is totally the opposite. The aforementioned tank makes it a very tight squeeze to get your hand/arm in. The bottom clip is hard enough.....but that top clip, don't say I didn't warn you. Took me about twenty minutes! The way I finally got it loose was this: sit beside the vent, your body facing the front of the car, use your right hand harm to access the top clip. This sounds the opposite of how you would want to do it, but it's what finally worked for me.
vent removed!
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-gvCXjZ5/1/L/DSC00683-L.jpg
Now that the vents are off we'll need to run a new wire to each vent from the parking light circuit. The easiest point of access for this that I could find was the wiring harness for the passenger side headlight. You will be looking for a small dark brown wire, with a grey stripe. It is near the end of one end of the plug, one wire between it and the end of the plug. I used a crimp splice connector, and tied my 18 gauge wire into that.
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-d8HwjDB/1/L/DSC00685-L.jpg
From there I routed the wire to each vent, splitting the wire into two with another crimp connector near the rear passenger side of the firewall. I tried to run the wire in such a way that it was hidden from view, would not get pinched/rubbed, and would not come into contact with anything hot. There is easy access on each side of the engine bay down into the side of the car, so this doesn't require too much work. I basically followed the passenger side of the engine bay, behind the air filter box, split the cable in the rear passenger corner of the engine bay. One wire went down to the passenger side vent, the other wire followed the firewall to the other side. I zip-tied it to an existing harness that runs along the top edge of the firewall, then down to the other vent. Anywhere I though the wire could come into contact with something that could damage it I used some corrugated plastic wire loom.
Now we should have three wires coming out of each vent hole; one parking light power wire (the one you just ran), one turn signal power wire, and one ground. The latter two of the three will be the existing factory plug. The ground will be the black one, the power will be some other color. I chose to use some more of those crimp connectors behind the factory plug so that everything could be reversed if for some reason you needed to. Next I crimped on some of the 18 gauge wire on each of the factory wires, behind the plug, about 6 inches each. The wires that will be coming from your computer header are two small for the crimp connectors, so this is a necessary step. Be sure to slide a piece of heats rink tube on each of the three 18 gauge wires you now have, we'll need this soon. Next use some cutters and carefully cut away some of the computer header, so that it's now a 2x3 instead of a 2x5 connector. This will allow it to plug into the connector on the back of the new vent.
computer header modified to fit new vent:
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-RfNvtCj/1/M/DSC00676-M.jpg http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-krvLqw7/1/M/DSC00680-M.jpg
Now, use my pin out and solder each of your three wires to the correct wire coming from the computer header.
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-9HrpcSb/1/O/007.png
The ground will go to pin 5. The parking light power goes to pin 2. The Turn signal wire goes to pin 1. The rest of the wires are not used. Next slide your heat shrink tubing over each of your solder joints and heat it up until it forms a good seal over each wire. At this point I wrapped the whole thing in electrical tape, and some corrugated plastic wire loom over that.
Now would be a good time to hook up your new vents and make sure they work. Turn on your parking lights, the light pipe should be white. Now turn on the hazards....a bright amber LED should start flashing, and in unison the light pipe will flash amber. Notice that in between flashes the light pipe is actually off, not white. Now turn off the hazards, the light pipe and LED will stop flashing, and the light pipe will remain off for a few seconds....then automatically go back to white! Here is my test run: http://youtu.be/jR2iuwTwjYU
Now comes the part of this mod that may stop some people from doing it. Some slight modification to the body panel is required. Luckily I have a good friend who is in that business who did it as a favor for me for free. If you choose to hire someone it should take them less than an hour to make the changes. If I didn't have the friend I think I could have done it myself. The two small holes at the bottom are perfect, and the lower of the top two holes is perfect. You will have to drill a new top hole, and make the large hole for the wiring bigger. I made a template to help me visualize it, and my body guy liked it so much he ended up using it. Said it made it much easier/quicker. If you make a good template, and line it up with the bottom two holes, and the one hole that still lines up at the top, the edge of the template running alongside the door should line up perfect.
version 1.0 and 2.0 of my template...note that you can use the same template on both sides, just flip it over!
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-Jc972VS/1/L/006-L.jpg http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-7wnH3pM/1/L/DSC00698-L.jpg
Tape it in place and this will let you mark off the changes you need to make. My body guy used an air tool with a grinding attachment make the big hole bigger, and then just a regular drill bit for the new small hole. We then used some touch up paint on any bare metal to prevent rusting. Keep in mind that even if you wanted to put the old vents back on you could! The original mounting holes are still there, and the modifications you made will still be covered up by the old vent!
body after we modified it:
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-cgT893P/1/L/DSC00690-L.jpg
Now if you/your body guy is as good as mine your vents will snap right in like the originals. Mine fit perfect, are nice and flush and tight! don't forget before you snap them in to plug in your new wiring harness, being careful to plug it in the right direction. I filled the void between my homemade plug and the outer edge of the plug on the vent with hot glue to prevent it from coming out, and to keep out moisture.
homemade plug/harness plugged in, and filled with hot glue:
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-fsZFTCQ/1/L/DSC00692-L.jpg
That's it. Grab a beer and appreciate your 2010.13 SRX!
http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-p8dV3Pr/1/XL/DSC00706-XL.jpg http://davedog.smugmug.com/2013/63013-SRX-Vent-Upgrade-Project/i-fqFV9NL/1/XL/DSC00707-XL.jpg
DTurmel
06-30-13, 11:40 PM
Cool mod! I always liked the vents on the 13s.
However I'm disappointed as I don't think I am up doing this myself. :(
Thanks for taking the time to share the instructions
Marc NY
07-01-13, 12:15 PM
:worship: Awesome job! Thanks for taking the time to document this for those that might want to try this great mod out. :thumbsup:
TheCaptain
07-01-13, 01:18 PM
Awesome job Dave!
RippyPartsDept
07-01-13, 07:31 PM
:yeah: awesome job and write-up
This is what the forum is all about
:thumbsup:
derek98z
08-08-13, 05:24 PM
Very awesome write up
btk301
12-22-13, 12:13 PM
Holy Crap...Thanks for the information. Glad I didn't even try it. I'm an "old" mechanic, by trade. Not a mechanical engineer. Not even going to attempt it. Thanks so much anyway...
Barry
Ludacrisvp
12-22-13, 02:18 PM
:thumbsup:
So have the number of fender vents being ordered through you spiked since the post of this? :)
Sent from AutoGuide.com App (http://www.autoguide.com/mobile)
RippyPartsDept
12-22-13, 09:52 PM
.... LOL ... zero orders total :)
mm9351
12-22-13, 11:04 PM
Nice mod! But the turn signals are hopelessly lost, correct? Seem like a compromise...
Ludacrisvp
12-22-13, 11:26 PM
Looks like a stealth turn signal to me...
https://www.youtube.com/watch?v=jR2iuwTwjYU
http://i222.photobucket.com/albums/dd198/MarcNY/DSC_7648.jpg
westham
12-26-13, 02:15 PM
A very cool Mod, but a lot of work to do the change out, I think I'm sticking with the original side vent. But thanks for posting it was very interesting and very well written and presented.
algiorda
12-27-13, 11:35 PM
That is a sweet upgrade. I would love to do it. Maybe I can talk my son into doing it for me, he's pretty good with this stuff.
Thanks for the write-up...it's really appreciated!!!
davedogcaddy
03-29-14, 12:19 AM
Sorry Buddy! ;)
At least I know I may still have the only '2010.13' SRX out there! lol :cool:
Indy_Mike
03-29-14, 12:46 AM
I wish I could pull this off....I already have the 2013 polished aluminum 20" wheels on my 2012, if I had this mod my 2012 would almost be a 2013 on the outside! Thanks for these excellent instructions!
RippyPartsDept
03-31-14, 12:23 PM
Sorry Buddy! ;)
nothing to be sorry about even though we're still at zero orders... :)
GTPprix
03-31-14, 12:26 PM
Awesome!!! Only thing I would be concerned about is overdriving those LED's. The BCM calibration was changed to account for the voltage requirements between the incandescent and LED bulbs from 12 to 13; just a heads up :)
davedogcaddy
03-31-14, 12:34 PM
Confirmed ahead of the mod that the two circuits used are 12v. This mod is still working great to this day.
I would think all they would have done would have dialed back the AMP requirements, having the extra AMPs on the LEDs shouldn't hurt anything - they will only use what they need. As long as the voltage is correct you are good.
GTPprix
03-31-14, 12:41 PM
EDIT: I apparently derped out. They did change the output but its not PWM LOL Its so minor it wont even matter; win!
davedogcaddy
03-31-14, 01:06 PM
it's OK. it's Monday. You're allowed. :)
P.S. you seem to know a lot about these vehicles....where were you when I was trying to figure this all out!? ;)
GTPprix
03-31-14, 01:26 PM
Hiding in a corner LOL :D If you need anything drop me a line!
Huey Driver
04-01-14, 12:51 PM
Interesting thought I just had. Due to the 'one way' nature of LEDs (esp 'diodes') dont you need a resistor on the anode side to control current? Probably not, but it might be that when replacing an incandescent bulb it would. I wouldnt worry about overdriving the LED, except for the cost, since worst case it burns that out. I'd be a little cautious tho that whatever is driving the circuit doesnt exceed its rating...
davedogcaddy
04-01-14, 01:28 PM
If you watch the video where I tested the vent you will see that the vent does things 'on it's own'. (like switching back over to the light tube to the color white after it senses no more voltage from the turn signal circuit) - so I think it's safe to say whatever is needed - as far a resistors and what not - are built into the vent already. There is likely a whole mini PCB board in each vent controlling everything, stepping down voltages, etc. Since we confirmed from Rippy's schematics that the vents run solely off two 12v feeds (one for the parking lights, and one for the turn signals) I just can't see them getting damaged. I think all Cadillac did was develop the vents to work off the (12v) circuits that are already in place. As far as over-driving the existing circuit - these LEDs pull way less than the incandescent lights they replaced.
But as they say, the proof is in the pudding....I did this mod in July of last year and it still works beautifully. I think if something were going to die it would have by now.
Huey Driver
04-01-14, 05:27 PM
In retrospect, agreed. All the stuff is probably already in there.
FLTRI
08-07-15, 06:39 PM
Just found this thread after buying a pair of take off 14 side vent/lights on eBay. I had hoped they would be plug-n-play, but found out they are not. I actually put them back on eBay. I figured out I could do the "fitting" part, but those six pins (vs. 2 on my wife's 2012) would be a problem. I figured all six pins had a purpose, and was worried about confusing the body computer.
Thanks very much to the OP for the tutorial. I canceled my auction, and ordered two of the USB plugs. An afternoon with some wire, a beer and a Dremel tool are on my plate for next weekend.
Again, sorry to revive an old thread, bit I sincerely appreciate Dave's well written, and thought out post! :highfive:
As an aside, I found it pretty easy to "pop" off the old gills. I used a plastic detail tool (Like a plastic butter knife) and simply pried the old part off. I ended up breaking one clip, but the eBay part had them, so no big deal. I had pulled the fender liner, but like Dave said, dang near impossible to get to the drivers side clips...
davedogcaddy
08-07-15, 06:44 PM
Again, sorry to revive an old thread, bit I sincerely appreciate Dave's well written and thought out post! :high five:
thank you for the kind words FLTRI! Let us know how it goes, as far as I know you will be the second one with this mod! :D
P.S. mine are still working great and have confused the hell out of some service advisers and SRX fans. :D :D :D
JohnEdwards1297
08-15-15, 11:46 AM
Amazing write up. Thanks for posting. Seems like only a near professional could do this mod but you certainly showed how one would do it if one had the skills. Besides cost and the amount of work, a concern I thought of regarding this would be cutting into the body and creating areas which might rust in the future. What if anything did you do to guard against that?
FLTRI
08-21-15, 06:23 PM
I received the USB cable yesterday, cut it down and it fits as advertised. I made a template using Dave's excellent instructions, and went to work. I did a few things differently. Not criticizing Dave's work, just adding my $0.02 on what I did, should anyone else want to take this on.
First of all, I jacked up the car and removed the front wheels. Once off, I pulled the entire inner fender liner. About 8 screws and three of the plastic push pins. This made running the new wire very easy, and I found lots of void areas under both fenders to run the wire and secure it with zip ties.
I used tins snips (I was a sheetmetal worker years ago, still have all of my implements of destruction) and carefully cut out the larger recess for the new light. If you remove the top clip on the new lamp assembly, you can test fit your cut-out, before you drill the new hole for the top clip. Once I was satisfied with the fit, I used a Dremel with a grinder attachment to clean up my cut, and eliminate burs and sharp edges. I center punched the fender through the template, drilled a pilot hole, and then drilled with the proper sized drill bit. Be advised that when drilling the drivers side, there is a plastic windshield washer reservoir right behind where you are drilling. Go easy, and don't drill into the reservoir. That would be bad thing... I have some GM touch up paint in Black Raven, so after the holes were done, I covered all bare metal with paint, to eliminate any chance of rust.
I cut the old plugs off, as I'll never go back to the old style lights. I taped into the wire Dave described, and ran new wires to both sides. I soldered the new running lamp wire as well as the existing ground and turn signal to the USB, and shrink wrapped the connections. I used electrical tape to seal up the USB to lamp assembly. I was a little concerned about how thin the aluminum wires were in my USB plugs, so I want to be able to get it back apart in the future if necessary.
Lastly, I found I could pry off the old lamps without having to contort myself too much with a pair of pliers from the inside of the fender. I have a plastic detail tool, that basically looks like a plastic popsicle stick. If you carefully slide it in, you can push on the clips from the outside, and pry at the same time. All four clips popped off easily, and didn't break.
I bought the light assemblies on eBay for $80.00 There are a bunch of takeoffs there, apparently folks are swapping them for optional ones in black chrome. The USB plugs were ~$5.00 After I got the lamps and realized they weren't plug-n-play, I gave up and re-listed them on eBay. Two days later I found Dave's tutorial, and pulled the auction. It's not changing oil easy, nor is it rebuilding a transmission hard. You do need some kind of mechanical ability, and not be afraid to take a drill, snips, and a grinder to your fender. Measure twice, cut once. I'm not concerned about rust as I sealed up the bare metal with GM paint. And I live in Las Vegas. It rains here, almost never...
Here's some video of them working, and a few pics I took during the job. Please excuse the comments, I took the video to send to my wife, it's her car after all...
Dave, Again a Huge Thank You! Had you not posted this great how-to, I would have scrapped the idea. Your pin-out diagram was printed and used during the job. I literally could not/would not have done it, if you hadn't taken the time to do it to your SRX, and post the details. I owe you a beer...
Work in progress. Wiring was done, so I had put the liner and wheel back on. Note the template in place for cutting and drilling...
http://i25.photobucket.com/albums/c67/FLTRI/6F27B764-EDE2-4BE1-B961-E3C0928C5850_zpsf6luxpsw.jpg (http://s25.photobucket.com/user/FLTRI/media/6F27B764-EDE2-4BE1-B961-E3C0928C5850_zpsf6luxpsw.jpg.html)
The template, and some of the metal I cut from the fender...
http://i25.photobucket.com/albums/c67/FLTRI/332FE6FC-E2A0-46DD-B586-A96AF850AEB6_zpsih17dvyt.jpg (http://s25.photobucket.com/user/FLTRI/media/332FE6FC-E2A0-46DD-B586-A96AF850AEB6_zpsih17dvyt.jpg.html)
Template, scraps, and a well earned beer...
http://i25.photobucket.com/albums/c67/FLTRI/B6F4647F-ED7B-4F72-98F4-6CCF01686E4B_zpsxfhqydpr.jpg (http://s25.photobucket.com/user/FLTRI/media/B6F4647F-ED7B-4F72-98F4-6CCF01686E4B_zpsxfhqydpr.jpg.html)
Couple of videos I shot for my wife at work. Feel free to ignore the "I Love You's" they were shot for her..
https://www.youtube.com/watch?v=e_A-jrBJ0f8
https://www.youtube.com/watch?v=5YunREsFucg
FLTRI
08-21-15, 11:33 PM
And to complete the update, found some (IMHO) better looking late model wheels. The red calipers are my own doing...
http://i25.photobucket.com/albums/c67/FLTRI/AA79E0D7-A2EF-4817-A59E-F3BC9EC7E364_zps1j8wvomn.jpg (http://s25.photobucket.com/user/FLTRI/media/AA79E0D7-A2EF-4817-A59E-F3BC9EC7E364_zps1j8wvomn.jpg.html)
http://i25.photobucket.com/albums/c67/FLTRI/5BE50F61-C8CE-472F-B721-C6A64DE1AC32_zpsjkptoibi.jpg (http://s25.photobucket.com/user/FLTRI/media/5BE50F61-C8CE-472F-B721-C6A64DE1AC32_zpsjkptoibi.jpg.html)
She said she wanted wheels that looked like my V... :yup:
http://i25.photobucket.com/albums/c67/FLTRI/E1CEB679-9DD5-4D15-A941-DBEE6ABAD9A4_zps4qcbhyul.jpg (http://s25.photobucket.com/user/FLTRI/media/E1CEB679-9DD5-4D15-A941-DBEE6ABAD9A4_zps4qcbhyul.jpg.html)
ce8204
08-25-15, 12:44 PM
that is verrry cool, i love the mods & the wheels!!!
b4z
09-13-15, 06:22 PM
Wish someone would delete the side vents altogether. That vertical element behind the front wheels visually shortens the car IMO. My car is a lease so I will not be the one to do it.
