: Rear Strut/Air bag leak
Midnight
06-30-13, 08:03 PM
121633
After checking brake pad wear, I noticed squeezing the air bag made a hissing sound. Poured some soap on it and you can see where the air is coming out. This isn't normal right? I mean, if you were to "blow" into the inflation valve it just bleeds right out the top. I figured if it went bad, it'd be on the rubber part, it's pretty surprising to me that it'd be on the top.
I have never noticed my car sitting low or anything, and it's something I notice quite a bit when other cars are, but I guess I don't often carry a lot of heavy things back there either.
Here's the label on the front of the strut in case someone is wondering.
121641
1BadCadSTS
06-30-13, 08:28 PM
Air should only come in and out of the valve where the air line connects. Anything else is a failed strut bag.
Ludacrisvp
06-30-13, 10:09 PM
I would replace it sooner rather than later. Not sure how long your compressor will last being on all the time to compensate for the leak.
1BadCadSTS
06-30-13, 10:37 PM
Correct!!!
Guy.Seminerio
06-30-13, 11:20 PM
yep. On previous caddy's with the air suspension in the back, I've had leaks but caught them early. The only way I knew was that when there was a load in the back, about 50% of the time I'd hear the compressor working but the car remaining low. But with no load, the car looked normal. If I never changed it, I'm sure I'd eventually see sagging with no load.
Midnight
06-30-13, 11:22 PM
Thanks guys. Going to see if Rippy can hook me up with a new one. :thumbsup:
B1n2fra
07-03-13, 02:43 AM
<img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=121633"/>
<img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=121641"/>
Same place mines leaked at. I was shocked also that it would leak there rather than the bag itself. Weird if you ask me. Maybe a flaw in design
