: 05 ESV Air Ride Compressor Not Running Even After Replacing
BlueOvalKid
06-29-13, 01:25 PM
2005 ESV Platinum
Air ride compressor was not running. To diagnose I looked at fuses and jumped relay pins and still wouldn't turn on.
Based on above I bought a replacement compressor from Arnott and replaced it along with rebuilding the dryer.
Put everything back in and the compressor is still not turning on.
What do I check at this point?
the cadillac man
06-29-13, 02:54 PM
2005 ESV Platinum
There should be a couple fuses in the under hood fuse box check those and also check the stud 1 fuse
BlueOvalKid
06-29-13, 06:01 PM
I need to know what is feeding pins 85 & 85 on the relay circuit.
I have a good 12v on pin 30. If I jumper pins 30 & 87 the compressor will turn on manually now. So, I know my replacement Arnott is ok.
What is feeding the 85 & 86 lines on the relay to open that circuit to kick on the compressor?
the cadillac man
06-29-13, 07:34 PM
Check the rtd fuse in the underhood fuse
BlueOvalKid
06-30-13, 07:35 PM
I have checked & double checked every fuse under hood and the IGN3 on the interior fuse panel.
the cadillac man
06-30-13, 09:10 PM
I would check the connections
BlueOvalKid
07-01-13, 10:16 AM
Can you elaborate or can anyone else provide some guidance?
the cadillac man
07-01-13, 11:33 AM
I was talking about the harness at the compressor check it
BlueOvalKid
07-01-13, 03:17 PM
Pin 30 has 12v with key OFF
Pin 85 has 12v with key ON
Jump either to pin 87 and the compressor turns on (obviously dependent on key position).
What feeds pin 86 to complete the relay circuit? I'm thinking it has to come from either the compressor or computer to signal the relay to close the bridge to pin 87.
Does anyone have a wiring schematic for this relay and what circuits control it?
the cadillac man
07-01-13, 04:14 PM
Send me a pm with your email(if my inbox is full let me
Know as the iPhone app doesn't let me
Know how full it is)
BlueOvalKid
07-01-13, 07:15 PM
Sent
the cadillac man
07-01-13, 08:49 PM
Sent
Got it
BlueOvalKid
07-02-13, 02:50 PM
If I'm looking at the schematic correctly then pin 86 of the relay is controlled by the ESC computer, correct?
I have checked all other pins of the relay and they are working properly.
Since I don't have any DIC messages would this point to the ESC computer being bad then and I need to replace?
the cadillac man
07-02-13, 04:54 PM
I would see if the fuse isn't blown for the module
You are correct on the pin
pmartell12
07-02-13, 07:26 PM
try starting it and putting in in drive... I saw that worked on the million dollar post
the cadillac man
07-02-13, 09:18 PM
Mine kicks on even in park
BlueOvalKid
07-03-13, 03:24 PM
There is no fuse for the ESC Module circuit that feeds pin 86 on the relay.
dahubby98
10-30-13, 06:02 PM
Sent
I sent a pm also. could i bother u for a copy, thanks
