: Northstar Engine assembly - instructions
Loose screw
02-14-05, 07:57 PM
I have searched the site and the web but for some reason I have been unable to locate a good detailed guide to rebuilding a (94 Concours) Northstar engine. I need it all, particularly cam timing instruction this looks tricky. The engine spun a bearing at 142,000 The crank has been repaired and two good connecting rods and new bearings and rings obtained. I have a Time insert kit (man was that expensive)to do all the head bold threads which have not been damaged but from what I have read it is a must do.
The timing chains look good but all the wear pads are completely worn out.
I do need to replace ALL the timing chains too don't I dispite how they look?
And what about the sprokets that look very good?
What gasket sealers are best and in which locations? any thing used on the head gaskets?
Do I really need new head bolts?
What are the biggest and most comon misstakes to watch out for?
Please supply any links and any and all info I may need or find helpful as this engine has to go back together this weekend. As you can tell I have all the stardard questions and few too answers or sources to find them - please help I sure don't want to screw this up with just what little information I have. Thank you
Loose Screw njvandermeide@msn.com
Ranger
02-14-05, 10:42 PM
I'm not expert but our resident expert has said the pads are not worn out. My understanding is they just wear an initial groove and then stay that way forever. Leave the chains alone.
Yes you need new head bolts. The old one are not reusable on the Northstar. I think they come with the gasket set if I remember what others have said.
eldorado1
02-14-05, 11:39 PM
I don't think you can get by without purchasing a factory service manual from either Helm, or off ebay... last I heard Helm was cleaning closet, and had a surplus of pre-95 manuals for $30 or something. There's another link about it, check the forum.....
Ranger
02-14-05, 11:46 PM
That goes without saying. I assumed you have one. "Don't leave home without it"
zonie77
02-15-05, 11:59 AM
This should give you some extra info.
http://www.cadillacforums.com/forums/showthread.php?t=5052
Pjs
02-15-05, 03:27 PM
You really should see the diagrams in the factory service manual for timing set. It looks a lot more complicated than it really is though. One thing that helped me was to put components removed in labeled sandwich bags. My engine at this point had 139K on it, the pads all had grooves in them but really weren't worn out as you would expect to see with a conventional engine. I've changed literally dozens of timing chain sets and never have I seen a set look as good as this particularly with the high miles. This is how your set should look after reassembly.
Loose screw
02-15-05, 07:54 PM
Thank you for the replies, the links to other threads and photo of the cams and chains they are all helping a lot.
Most of the chain pads were completly worn through on this engine, possibly due to low oil given the fact it had spun a bearing and there was plenty of oil starvation marks on the other bearing.
As for a good shop manual sadly no the only one I was able to get - when it arrived - it didn't cover engine rebuilds or even tear downs - "it should be left to professional". So I am stuck and out of time. I am hoping for something excellent on line. I need all the info I can get so again please post or email what you can, I'm really am disperate and the weekend is coming fast! njvandermeide@msn.com
zonie77
02-16-05, 01:55 AM
Where are you located?
The library in Phoenix has alldata online. Maybe the library near you does also.
If the community college has auto courses they may have a library in the auto ctr. One of the cc's here has a lot of manuals available and has Mitchell's and Alldata online. This is in the Auto bldg...not the school library. Just a couple of ideas.
Loose screw
02-16-05, 11:11 AM
I am in Salt lake City Utah I did check the libaray's Automotive reference section but I didn't think to see if they had anything additional online - thanks I will check it out for sure.
Loose screw
02-16-05, 11:18 PM
What gasket sealers should I use and where and where not.
Is anything being used on the head gaskets?
BeelzeBob
02-16-05, 11:24 PM
Use an aneorobic sealant like Loctite "gasket eliminator" on the lower crankcase to block joint in addition to the silicone rubber side seals in the grooves.
Use the OEM head gaskets and new head bolts that come with the head gaskets. Do NOT put anything on the head gaskets....unless you want them to leak and fail....LOL.
Loose screw
02-17-05, 04:08 AM
Thank you - just what I needed, a specific answer.
