View Full Version : What do you use for your jacking solutions?
M5eater
06-28-13, 08:02 PM
It looks like what you have to do is lift(using a floor jack) from the pinch welds as indicated from the rocker panels and then slot the jacks under the circular points on the unibody.
Corvette pucks might be a suitable replacement for the stands, just wondering if anyone here has found a better solution. for the stands and what you use to jack on the pinchwelds.
thinking about picking up some of the corvette pucks form amazon and these
http://www.purems.com/Products/PROTECHSIDEPADProtech-Side-Lift-Jack-Pad
need to measure the pinch area to make sure they'll fit through.
thebigjimsho
07-02-13, 11:31 AM
Why are you asking?
M5eater
07-02-13, 02:18 PM
the area of the jacking point is odd in this car, it's at a slight angle, so you can't plant it on a level surface.
I ended up cutting up some wood, but it certainly didn't look safe.
thebigjimsho
07-03-13, 07:28 AM
I meant this was the first post I saw where you may have bought an ATS...
M5eater
07-03-13, 08:31 AM
oh well.. get with the program!
Hoosier Daddy
07-03-13, 09:06 AM
Glad you cleared that up. I was wondering why you were asking why he was asking.
Stevo Supremo
07-03-13, 10:43 AM
I put span a 2X6 under the car where those two holes are, the ones near the front pinch point(factory hoist holes) and put a jack under the wood, have lifted the car numerous times with no issue
M5eater
07-03-13, 10:53 AM
Sure, but where do you place your stand after that?
I had to lift from the pinch and put the stand where the holes are supported by a block of wood.
Bertha D Blues
07-03-13, 01:59 PM
This was my crude prototype to fit the seam/pocket area. I'm planning to build an aluminum version when my machinist gets back from vacation. I left the seam groove a little wider than needed because I plan to lay tooling urethane into it to protect the seam from localized damage. Bert
122298122306
M5eater
07-03-13, 02:19 PM
122298122306
question.
How much bribe money do you need to do 2?
Bertha D Blues
07-03-13, 08:49 PM
Ooooh! I smell a group buy coming.
Kidding. Bert
I asked Cadillac Customer Assistance for jacking point info. This was their response, poor grammar and all.
"Front of vehicle:
Place service jack pad on the lift pad located right next behind the left and right wheels or on the front center jack pad which is located at the front-center of the vehicle where two arms are connected.
Rear of vehicle:
Place the service jack pad on the lift pad located right next front the right and left wheel."
Huh? Well, that's what they wrote. Cheers. Bert
73JPS
07-04-13, 01:06 PM
Kidding. Bert
"Front of vehicle:
Rear of vehicle:
They almost certainly hired the guy who writes the manuals for Chinese products.
Felton10
07-07-13, 01:11 PM
Isn't that sort of a personal question?
wongluk
07-07-13, 04:46 PM
Meiki or onaholes or torchlight and lube... Lots of it....
Sent from AutoGuide.com Free App (http://www.autoguide.com/mobile)
