: oil change help please
ukmat71
06-28-13, 07:17 AM
121065
I think i must be going mad , trying to change the oil but something is telling me somethings not quite right.
I have been changing oil on my cars for the best part of 30 years but not seen the underside like the srx, wheres the oil pan , im used to a great big black sump.
oil filter , not a problem , i can see it at the top on the side.
but the oil drain bolt. i think i found it , but researching not 100% and wondering if the UK models are slightly different to the US ones.
some posts say this is correct , but some say not this one.
so can someone tell me if i am looking in the correct place , i think i am but like i said , having a brain lapse and not sure.
also what type of oil is more suited as my manual does not seem to specify i know its 5w-30 , but fully synthetic or semi-synthetic.
any help very gratefully received.
arw1510
06-28-13, 07:25 AM
<img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=121065"/>
What year is the car? My srx used to say Mobil 1 full synthetic right on the oil fill cap
ukmat71
06-28-13, 07:27 AM
2007 3.6 V6
but just has on the cap 5w-30 , possibly an aftermarket cap
glake89
06-28-13, 09:43 AM
That's the drain plug, and full syn. only.
repnatl
06-28-13, 09:52 AM
Drain plug is a 15mm
ukmat71
06-28-13, 12:02 PM
Thanks guys for the help. I thought I was correct but just wanted to double check.
n7don_srx
06-28-13, 02:02 PM
If this is your first oil change some have found the oil filter cap to be difficult to unloosen. I recall it takes a 24 mm socket.... 15/16" also works and the torque spec is 18 lb-ft.
My domestic manual shows to use oil meeting GM4718M specs and having the starburst symbol on the container. I'm not aware of any non-synthetic oil meeting this spec.
conedoctor
06-28-13, 02:17 PM
I dropped my Talon off at the local speed shop to change the transaxle, t-case and rear diff fluid change to RedLine, anyway I get a call about an hour later asking me what kind of oil I use in the engine lol
It happens to the best....
