: Steering play - options?
70eldo
06-28-13, 02:41 AM
I have a slight play in my steering. Is there anything I can adjust to reduce or eliminate the play? Or do I have to replace hardware?
I checked the joints and they are OK. The play seems to be internally in the steering gear.
70eldo
07-29-13, 04:34 AM
Bump
Noone ever fixed this?
MoistCabbage
07-29-13, 04:53 AM
Not sure if your steering gear is adjustable. If not, it will need to be replaced.
carnut
08-01-13, 12:45 PM
Assuming the coupler is tight where the steering shaft meets the gear box, you will see a jamb nut and screw slot on a bolt at the top center of the box itself. Loosen the jamb nut and turn the screw a quarter turn clockwise and tighten jamb nut. If it feels the same, I would look at tie rods and idler arm for play.
70eldo
08-02-13, 05:15 AM
Thanks! I've seen this adjustment by that screw on a jeep and wasn't sure if it would be the same on the Cadillac. I will try this out and go from there. Tie rods and idler arms have been replaced a couple of years ago. I am sure I can see the steering 'axle' turn before the steering housing without resulting action within the play movement. That is why I presume the play is within the steering housing.
carnut
08-02-13, 06:59 PM
If you turn that screw too far, the steering wheel will not return to center once you turn the corner. Be careful!!!
70eldo
08-04-13, 09:16 AM
OK, I will be carefull. ThnX!
