: Wheel removal help
Chosenone
06-28-13, 12:37 AM
I am trying to get the rims off my ctsv and cannot figure it out. I have thr llugs off but the rim wont budge now. Am i missing something? Does center cap come off and how does that come off?
spearfish25
06-28-13, 12:44 AM
Should just be: remove five lugs then pull
May just need some elbow grease if the hub has corroded a bit. When you put them back on, put some anti-seize on the hub where the wheel slides on. Don't put it on the wheel studs though.
thebigjimsho
06-28-13, 12:46 AM
Use a rubber mallet and give light/medium whacks around the edge of the rim...
bbradyc5
06-28-13, 11:07 AM
just take it for a drive, they'll loosen up ;)
j/k.....do not do this (this is my disclaimer)
tinman
06-28-13, 11:15 AM
I used to have to do this with my Camaro. I carried that rubber mallet inside my car for "emergencies".
I used to what my tire, not the rim. If you want to rock the rim, get a rubber "dead blow" mallet. That's a rubber mallet with buckshot inside to give it the ooomph it needs to make the blow, but being rubber it is soft and non-marring.
Use the rubber mallet on the rubber tire. Or a bottom of your foot while sitting down in front of it. And spray some WD40 on the hub when re-assembling.
spearfish25
06-28-13, 11:27 AM
Yes. PB Blaster can be your friend.
cdog533
06-28-13, 11:35 AM
You need a BFM.
RaVeNous
06-28-13, 01:05 PM
"Beat" me to it...
And work on your abs/core strength.
RogersV
06-28-13, 03:56 PM
From the back side works best.
thebigjimsho
06-28-13, 07:45 PM
"Beat" me to it...
Then you get Recaros!
CJCTSV
06-28-13, 08:14 PM
Pull harder... I've had this issue before as well... the center hub is a very snug fit into the wheel.
