: Transmission bypass valve removal due to "Hot Trans Idle Engine error"
royan97
06-28-13, 12:40 AM
I have a 2004 srx V8 and I have just change my transmission oil. driving for only around 300km and I notice my transmission fluid life is down to 96%. Before I have read about the 2004 model having a bypass valve for the transmission line that was remove on the 2005 model because it was susceptible to getting stuck in the close possition. I have this car for 3 years already and have change the transmission oil twice already. I also read that the transmission cooler lines can be replace by the newer kind which does not require the bypass valve.
Has anyone experience the process of replacing the transmission cooler lines. Is there a way to check if my transmission fluid is circulation properly or determine if my bypass valve is stuck in the close position.
I don't know maybe I need to replace my transmission coolant first before replacing the transmission cooler lines. I also took a picture of what I think is the bypass valve.
SFVetteman
06-28-13, 12:54 AM
Given the climate where you live, combined with the fact that the bypass valve was discontinued after 2004, I think the best thing to do is to remove the bypass valve and install the later transmission coolant lines.
Bill
royan97
06-28-13, 02:52 PM
Can any body provide me with the part number of the new coolant lines (upper and lower) without the bypass valve. The only dealer here seems clueless since I complain this already and they said everything was fine and just change my transmission oil and filter.
SFVetteman
06-28-13, 10:35 PM
You should PM Chris the parts guy at Rippy Cadillac. He posts under the handle of "RippyPartsDept" and is an authorized vendor.
Bill
royan97
07-02-13, 03:55 AM
ACDELCO Part # 19129780
HOSE,TRANS FLUID CLR Upper USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934-FOR CARS BUILT PRIOR TO VIN REPL T/W 19129779 ,11515757 & REMOVE THERM BYPASS VLV.
* Stocked in outlying warehouse--shipping delayed up to 5 business days
$18.00
ACDELCO Part # 19129779
HOSE,TRANS FLUID CLR LWR USE TOGETHER WITH 19129780 ,11515757 & REMOVE THERM BYPASS VLV.
royan97
07-28-13, 04:03 AM
Transmission life update:
June 28, 2013 - 96%
July 28, 2013 - 70%
n7don_srx
07-28-13, 10:14 AM
I'm not sure of your ultimate intensions.... do you intend to remove/replace the existing bypass unit? Just waiting on the parts?
Admittedly I'm flying blind as I've never seen the "innards" of the unit but most thermal bypasses I have seen have some type of bimetal element that covers or uncovers an opening to redirect flow. If you have access to a hoist and/or a trusted mechanic perhaps it would be worth while to remove and inspect the bypass valve to determine if it could be modified to eliminate the thermal element.
royan97
08-28-13, 02:21 AM
I already got the new transmission lines without bypass valve. Just waiting for my oil life to reach 0%. Here it cost almost $300 US to change transmission oil and filter.
June 28, 2013 - 96%
July 28, 2013 - 70%
August 28, 2013 - 60%
n7don_srx
08-28-13, 08:09 AM
Assuming the apparent rapid depletion of oil life is related to a high fluid temperature aren't you risking damage to your transmission by waiting?
DougC..
09-16-13, 06:17 AM
Doesnt the life % come from miles driven? I mean, you dont think that its testing your fluid each time you start the car.
MoistCabbage
09-16-13, 06:38 AM
It works in a similar way to the OLM, it doesn't test the oil, it monitors several parameters (miles, RPM, temp... It should also go straight to zero if the fluid is overheated.
rabee
01-19-15, 08:42 AM
hello"i clean all cooling fluid line"so radators""nd chang trans fluid filtter nd new fluid"" and stell my cadillac transmissons very hot""trans hot idle engine}this indcator stell on"after draiving 150 mils"" can i chang pypassvalve??please any one has idiaer"can tellme""thanks
Tiger1106
01-19-15, 01:26 PM
Had a problem of trans overheating after driving at high speeds a couple of years ago. A change of the valve (about $40) solved the problem up to this day. Of course, I changed the fluid after that. Don't see the need to change pipes.
rabee
01-22-15, 01:01 PM
what happen"after u cahnge pypass valve"??? please tell me""
Tiger1106
01-23-15, 04:52 AM
It never overheated again.
SRX_Jim
04-26-15, 07:13 PM
I am a little confused, my VIN is 1GYDE63A840140940 so what parts do I need to eliminate the bypass valve? Please help this just started this week on every long drive. Do I replace with 2 19129779 lines? Also do I need the 11515757 bolts?
Tiger1106
04-27-15, 01:59 PM
I replaced just the valve and it solved the problem.
Jim_V
04-27-15, 10:06 PM
When I look at parts site they do t list the valve for my VIN number.
