: Why and what is it making that noise? (Video included)
DReffects
06-27-13, 07:24 AM
Hey Guys,
while detailing the car and having the doors open i've noticed odd sounds in a non pattern kinda way coming from the engine compartment. I've took my camera and found it to be this part:
http://www.youtube.com/watch?v=2mxA6VWZy2A
Unfortunatley i do not know what this part actually does/is nor why it keeps making this sound while the car isn't even running.
thanks!
cadillac_al
06-27-13, 09:43 AM
That is the air compressor for your rear struts. You must have a leak, usually the struts when they get 20 years old.
DReffects
06-27-13, 11:43 AM
So that's why the "Service SSS" lamp is on? ;)
Could you please help me pick the correct struts at http://www.rockauto.com/ ?
I don't want to loose that auto leveling thingy and electronic ride control, thanks :)
cadillac_al
06-28-13, 10:16 AM
Oh yeah, 93 has the SSS struts and it appears that Rockauto doesn't stock them. Probably nobody has them. You could get regular struts and deal with the SSS message. Somebody will come along and clear this up.
I ran my Deville the last couple years with no air in the struts. It sat level when it was empty but I couldn't put much in the trunk and 2 guys in the back seat made it sag pretty bad. 95% of my driving was solo so it wasn't a high priority for me. You may want to unplug that compressor if it runs too much, to save it for when you do replace the struts.
DReffects
06-28-13, 11:17 AM
Damn :( is there an official description/name or a part number for these?
I found a way to disable the "Service SSS" lamp, but I'd rellay like to have the car in original condition. Is there a downside to pulling the plug on the compressor?
Submariner409
06-28-13, 11:25 AM
The tail end will droop.
Look through your car, model, system in www.gmpartsgiant.com (http://www.gmpartsgiant.com). The level control compressor is trying to keep the rear of the car level. It does not sound healthy. Given the age of the system, the air lines and rear shock boots are probably toast, too.
Talk to Chris in parts at Rippy Cadillac, over there >>>>>>>>
DReffects
06-28-13, 12:26 PM
They don't seem to have parts for the rear suspension :(
In your opinion - do i loose a lot of ride quality if I replace the struts completely with fixed ones? I am unsure what the 'electronic ride control' actually does. Does it simply level the car when i put stuff in my trunk or is it an active suspesion that adjusts on the fly while driving over bumps like the newer cars have?
cadillac_al
06-28-13, 08:28 PM
Yes it is active suspension and it is supposedly expensive. I doubt the ride difference would be too drastic. The standard struts just level the car and have normal shock damping. Your best bet is to contact Chris at Rippy to get a definite answer on availability.
DReffects
07-02-13, 10:18 AM
I've emailed Rippy Cadillac but have not gotten any response yet, I've pulled the plug on the compressor for the time being.
BigCadMan_1
07-02-13, 01:21 PM
You will find what you need here:
http://www.monroe.com/en-US/catalog/e-Catalog
If you need a new compressor this one will meet your needs:
http://www.ebay.com/itm/88-DEVILLE-AIR-RIDE-SUSPENSION-PUMP-COMPRESSOR-/171068352570?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d477e83a&vxp=mtr#ht_2816wt_721
If you want to go the "passive suspension conversion" route, try these guys:
http://www.strutmasters.com/SearchRe...llac+Fleetwood
dennis93coupe
07-06-13, 02:37 AM
Right now you can buy Monroe SensaTrac rear struts for $35.79 from Rockauto.com You will not be able to find original SSS struts unless some pop up on ebay. They were discontinued in 2000. Get the sensatrac's with the bladder and tie back the harness that goes to the original strut.
DReffects
07-06-13, 11:05 AM
Thanks for the tip :)
RockAuto Customer Service actually recommended
. ACDELCO Teil # 903002RS {#19294055} ReadyStrut
http://www.rockauto.com/getimage/getimage.php?imagekey=3844392&imageurl=http%3A//images.whisystems.com/smartpages/partinfo_resize/DCL/903002RS_PRIMARY.jpg
and
. ACDELCO Teil # 903008RS {#19294057} ReadyStrut
http://www.rockauto.com/getimage/getimage.php?imagekey=3844290&imageurl=http%3A//images.whisystems.com/smartpages/partinfo_resize/DCL/903008RS_PRIMARY.jpg 300? 300: true ); height:expression(this.height > 400? 400: true );">
Aren't those the original replacement parts? Or just Acdelco 'aftermarket' parts without the air thingy?
dennis93coupe
07-06-13, 08:02 PM
You only have air in the rears. Just looking at the picture, those appear to be correct for the rear. The fronts look correct also and will save you the hassle of changing the spring and upper bearing assembly.
Ranger
07-06-13, 08:34 PM
Don't automatically assume it is the shocks. While they ARE in fact 20 years old, so are the air lines. Spray down the lines and fittings with soapy water. Let the compressor run and look for foam. That'll be your leak.
DReffects
07-07-13, 02:17 PM
Nice trick! Gonna try that before ordering. I've looked closely at the rear shocks and found the plastic 'airbag' to be veeeerrry worn down. lots of ripples etc. Is there a way to test if the front struts are ok or not?
DReffects
07-15-13, 06:20 AM
I've found the following picture for the front:
http://ecx.images-amazon.com/images/I/51USezl0TnL.jpg
Does not look like they have that electronical connector :( Any idea where i can get those?
