: 6 speen automatic gear oil BLS 2006
06-27-13, 08:15 AM
Does anyone know what kind of oil is needed for an Aisin Warner TF-60SC AF40 ?
I found this information in French :
it says JWS 3309 Esso for cars with Euro 4 engines (from 1/1/2006) and AW-1 for cars withs Euro 5 (from 1/1/2011), both oils can't be used instead of eachothers.
Any information here ?
06-27-13, 06:26 PM
I suspect you'll need this:
For euro-saab-parts, you will need to input part number 93165147 into the search box.
Never forget your car is a Saab lol!
06-28-13, 02:41 PM
My BLS is a 1.9 diesel that's why I mentionned the transmission details, are you sure the 93165147 is the right one ?
07-01-13, 02:41 PM
Sorry for the late reply, got to have a weekend away sometimes!
I'm assuming here your car is the TTID estate? I cannot commit myself to tell you that the part number I have given you is exactly what you require. I gleaned this information from just 5 minutes of looking on the web. You need to check with a Saab dealer or Saab independent mechanic or possibly an Opel dealer in France?
If you look again on the eeuroparts.com link I posted in my last post and read the manufacturer info, it should give you the information you require.
I'm sorry I can't be of more assistance. You could of course contact Bauer-Millett in Manchester or Evans Halshaw, Wavendon, Milton Keynes for further advice.
07-02-13, 04:37 AM
He's listed his BLS as an '06 the TTiD engine didn't come out till the '08 the BLS V1.1 came out, I think he has the TiD engine.
07-04-13, 10:03 AM
yes it's a 2006 with 150hp 1.9Tid 4 door sedan
Thanks for the link S70RMP, unfortunately there is no diesel, probably not sold in the US...
08-26-13, 03:18 PM
Any confirmation about this ?
08-26-13, 06:38 PM
More from the Saab forum---The Haynes manual quotes "AW-1 part number 93 165 147" as the correct fluid for the Aisin Warner 6 speed auto transmission.
This is a mineral-based oil (not synthetic). Saab advises against using synthetic oil, otherwise malfunction may occur.
The Aisin Warner AF40-6 utilizes "slip-lock technology" in it's design for changing gears. Sythetics are just too slippery for efficient "slip lock" functionality.
Αs long as the fluid meets the Aisin-Warner 'AW-1' spec, then it should be fine to use.
This info I beleive applies to my 08"ttid"As already stated be safe and ring a dealer for details.
08-27-13, 07:35 AM
Thanks to all of you for your information !!
I could not find the right info first because the gear is a 80SC instead of a 60SC that might not even exist, my mistake...:bigroll:
