View Full Version : What tire pressure for 24"?
grayparatrooper
06-27-13, 12:03 AM
I have 305/35/24 toyo tires. What's pressure should I run at? Currently at 40.
wesyder
06-27-13, 12:04 AM
I ran mine at 40psi as well
Silent_Assasin
06-27-13, 11:57 PM
Your sidewall should tell you ... my same size Lexani's tell me 44!.....Most tires are 35-40
Retrax
07-22-13, 07:16 PM
The sidewall will tell you Maximum PSI. The recommended pressure for the factory tires will usually be on a label in the door jamb. It is usually significantly lower than the max pressure printed on any tire's sidewall. Unfortunately it will specify the pressure for one specific tire size, not for all sizes, so it can be hard to figure out.
