View Full Version : Sunroof question
AmyinFL
06-26-13, 02:23 PM
My sunroof creaks while driving (like many others have mentioned.) However, also my shutters when it is shutting/vibrates about- 6 inches before it closes. Anyone have any idea of what could be causing that?
Also, has anyone here ever removed, cleaned and checked the rollers? Wondering what kind of job that would be.
Thanks in advance
~Amy
orandaberg
06-26-13, 02:46 PM
Hi
You need to grease the rear track, the one exposed to the elements on the rear of the roof, use lithium grease or similar(aerosol)with a spray tube in the nozzel, I am sure others will disagree, but they can add input. If that fails you need to check if your torx heads are tight, do a search on ultraview or sunroof and you may find more input, but do the search on this section of the forum not a general search or you will come up with every cadillac car
