View Full Version : I need info on the AMP for the 2006 DTS with BOSE
Superjim
06-25-13, 09:00 PM
I think one channel on my amp is bad.
The drivers side REAR DOOR speaker does not work.
I replaced the speaker with a new BOSE speaker and it doesn't work either.
Speaker part number 25725733.
I am not sure where the AMP is located and what it would entail to replace it.
Any troubleshooting advice to narrow down the problem is more than welcome... :)
danog
06-25-13, 10:42 PM
Jim
The AMP is behind the Rear Seat Back Cushion on the driverís side.
Take the trim off the B pillar post. You may have a Brocken wire between the B pill and the door.
Hook up some jumpers to the old speaker and at the b pillar connector PIN B4 white wire and B5 tan/orange if the speaker works there then you have a Brocken wire between the B pillar and the door.
Tom
Superjim
06-25-13, 11:04 PM
Jim
The AMP is behind the Rear Seat Back Cushion on the driver’s side.
Tom
Thank you.... I will check that out (hopefully) in the morning...
Jim
