: New headers, exhaust and muffler1970 Eldorado - pics
70eldo
06-24-13, 08:16 PM
Hi all,
Last weekend I had the headers installed from cad500parts along with a new custom (as in not pre-bent) stainless steel exhaust and muffler.
The exhaust I had under the car was only partly replaced in 1999. I had flowmasters installed that sound nice at low rpm, but start to blare and shatter at higher rpm. That just didn't fit the car nor my comfort.
The LH header cracked before and I had it welded in 2008. And now the pipe started to rot just before the muffler so I needed something new. Though I was amazed to see how well the pipes held over time as they were cut up. Really only the attachement to the muffler started to rot. The rest looked very well.
About cad500parts: I called them a few times for info and was assisted by Chris. He had a lot of good info for me. The headers were sent by FedEx and came in very quickly. I thought US Postal service was cheaper, but then the package would go through German customs and you have to pick it up there. Before you can pick it up they will take up to 3 weeks (!!!) before they checked it. Through FedEx wasn't much more expensive, but a LOT quicker and hassle free. The headers were a little scratched up, but that was just the zink coating that could easily be fixed.
About the exhaust shop: I went to EPS (http://www.uitlaten.com) in the north of the Netherlands. I had my exhaust done for my 2006 CTS before and was very happy with them. I couldn't find an exhaust shop in Germany anywhere nearer to Hamburg than this place in the Netherlands. I went to a general workshop (specialized in US cars) in Hamburg that quoted 3-4 days of labor for the exhaust, so that would've been way too expensive.
Anyway, the people from EPS are great. They do the whole thing within a day, so you can just hang around and wait for it. They use pre-bent pipe sections they did on the mandrel, so the diameter is constant. The welding is excelent!
We didn't do the X-joint (proposed by cad500parts) nor H-joint as that was not feasible due to the torsion bar suspension. The dual exhaust joins in the rear muffler anyway.
The headers have a 3" collector. By the way EPS said they receive custom headers from various suppliers in the US all the time and these headers from cad500parts fit exceptionally well. They replaced the flange on the LH header to get more clearance from the steering joint but other than that we only needed to move some hoses.
After the headers the pipes gradually go from 3" to 2.5" and then to 2.25" (like orignial size). The exhaust pipes are the lowest part under the full middle part of the car (between the front and rear wheels), so you wouldn't want to make the pipes too big. Another reason why an X- or H-joint would be too risky as that would be the first to hit and catch a curb or so (and rip and tear everything off).
I didn't check the brand of the muffler, but it is stainless steel and insulated straight through (non-baffled). So the pipe going in on top will leave on top and vice versa.
The whole system results in a decent but still sporty sound. And the car now runs a lot smoother through acceleration, shifting and desceleration.
http://i209.photobucket.com/albums/bb93/Bues_Almighty/IMAG2610.jpg
http://i209.photobucket.com/albums/bb93/Bues_Almighty/IMAG2609.jpg
To be replaced: (bend rotted temp fix with gun gum)
http://i209.photobucket.com/albums/bb93/Bues_Almighty/IMAG2606.jpg
RH header. Moving some hoses...
http://i209.photobucket.com/albums/bb93/Bues_Almighty/IMAG2611.jpg
BTW, I had to be there at 8 am. And since it is a 3 hours ride I had to get up early. That resulted in me forgetting to close the oil cap after I filled up the oil a little. Hence the oil spray... (first time in my life for this to happen to me!)
Continued
LH snug fit
http://i209.photobucket.com/albums/bb93/Bues_Almighty/IMAG2612.jpg
First bend from LH
http://i209.photobucket.com/albums/bb93/Bues_Almighty/IMAG2614.jpg
Progress on RH
http://i209.photobucket.com/albums/bb93/Bues_Almighty/IMAG2615.jpg
Progress LH
http://i209.photobucket.com/albums/bb93/Bues_Almighty/IMAG2617.jpg
Progress on the muffler
http://i209.photobucket.com/albums/bb93/Bues_Almighty/IMAG2618.jpg
Result LH front to back (I will consider fancy exhaust tips later; these are not too bad though)
http://i209.photobucket.com/albums/bb93/Bues_Almighty/IMAG2619.jpg
Video:
http://s209.photobucket.com/user/Bues_Almighty/media/VIDEO0314.mp4.html
Here's an old video from 1999 with the original paint and the Flowmaster muffler still in Tucson, AZ back then:
http://s209.photobucket.com/user/Bues_Almighty/media/70Eldoradoexterior.mp4.html
talismandave
06-24-13, 08:41 PM
Looks beautiful and sounds perfect!:thumbsup:
MrEightball
06-24-13, 10:34 PM
Nice! Those look and sound amazing
CADforce69
08-24-13, 11:27 AM
Great work and excellent headers... A good upgrading of your exhaust system. Most original headers are cracked or have some leak (my RH one have a broken bolt so you can hear the leak when cold).
Thank you for sharing with us :thumbsup:
CaddyGas
08-24-13, 12:09 PM
Don't believe I missed this thread. I like it and those are mandrel bends to.
70eldo
09-02-13, 05:21 AM
I had a broken bolt on the most forward bolt of the LH header before. It was cut out from the side and they welded the side shut again and tapped a new thread in the hole. That was just lucky it was the most forward bolt. If it was any more backwards, then drilling it out would be very hard. I know of some 90 degress drills (like pneumatic), but it would still be a tricky job. Hope you can get it fixed some time!
CADforce69
09-03-13, 07:59 PM
^Yes, you were lucky. My broken bolt is just the closest one to the firewall so if one day I decided to fix it I would have to take that head out :( but as soon as it gets near operating temperature you can hear no noise :D
70eldo
09-04-13, 10:49 AM
Make sure next time use anti-seize (like copa-slip) on the bolts :o
CADforce69
09-04-13, 02:46 PM
Good advice :thumbsup: Thank you for the tip.
70eldo
04-17-14, 07:03 AM
I found the vid from EPS in YouTube
http://youtu.be/mBbU2GHv6D0
talismandave
04-17-14, 07:42 AM
Very cool! :highfive:
CADforce69
04-17-14, 12:18 PM
It sounds beautiful! :thumbsup: Sound changes considerably from original exhaust system to dual. We can see a smile of happiness on your face in the last seconds of the vid so results must well be worth the money it costs :D
Jaykeane
04-17-14, 05:15 PM
I broke 6 of eight on the passenger side of my 73 eldorado.. 90^ air drill, and MANY shortened drill bits..
most useful tool was a 90^ die grinder with a pointed 3/8 bit.. was able to fire heli-coils in there.. it was tight..
IcebaerLars
04-02-15, 03:36 PM
Hi Martijn,
which parts have you ordered from cad500parts exactly?
Why have you choosen the new headers - I assume that EPS would have been able to go from the original headers flange (with a little longer pipe) as well ahead.
Thanks
Lars
70eldo
07-22-15, 08:15 AM
Sorry I reply WAY TOO LATE Lars!
I had the headers, bolts and flange gaskets ordered from cad500parts. EPS could've had it done too, but that would've been a lot more expensive as they woul've needed to messure from scratch and put a lot of man hours in it. cad500parts has them in stock and they fit like a glove.
I wanted to order a new header for the cracked (but repaired) one I had. But since the bigger headers were not much more expensive than new original style I just ordered those. I was going to have the complete exhaust replaced anyway. I am very happy I did, because it runs a lot smoother now.
IcebaerLars
07-22-15, 08:49 AM
Hey Martijn,
no problem.
But good to know what made your decision.
Thanks
Lars
goldentiger0711
04-20-17, 01:55 PM
@70eldo
Hi, thanks for sharing your experience with this project. Looks and sounds great! I also have a 70 Eldo and I followed your lead and purchased the same headers from Cad500. They originally sent me the completely wrong headers but corrected it shortly after. I even sent them your post for reference! Anyway, I'm having a slight issue with the driver side header, it's extremely close to the brake booster. Did you come across this issue? If so, how did you resolve it? I appreciate all the info and help!
