: 07 Escalade stalling when hot
Jmdkan
06-23-13, 03:13 PM
HELP........I TOO HAVE AN 07 Escalade. Was driving last week from NC to AZ towing my sons vw gti on an auto transporter . The first day which was the hardest because of up and down hills it did great. The second day about half way through I pulled into gas station and it stalled as I was pulling into pump. Tried to start and. It cranked but would not start. Got gas and went to restroom and tried again . This time it started but when it did it had no power and was barely running for like 2 -3 seconds then resumed normal idle. 3-4 hours later after running fine on the highway at the. Next gas station it did it again . This time called AAA had the vehicle towed and dropped the VW off the transporter off and had my wife drive it. Caddy dealer in NM had it for a day and could not duplicate or find nothing wrong. Continued our trip without transporter driving 2 vehicles. stopped for gas once and it did not stall. next stop was our destination in Phoenix . I came off highway to exit and hit a red light and it stalled. Restarted after 5 mins again low power at first and drove it right to Caddy dealer . After 3 days no luck at duplicating and no codes tripped. Also fuel pump was tested and checked out ok. It is out of warranty and I don't want to start throwing money at it guessing what's wrong ..........I do not want to trade it in . We love the vehicle bunt my wife is scared to drive it . It has 84 k if that helps .....Thanks. !
longmere
03-21-14, 03:28 PM
I have the same problem with an 07, runs fine on the highway and around town. After running about a half hour and it gets hot, it will stall at a light. It won't fire up with starting fluid but will start after cranking with the throttle full open (which doesn't make any sense) Replaced crankshaft sensors and throttle body sensor. No codes. Please post on what or if you finally found the problem.
ticktock
03-21-14, 10:32 PM
Do a search on this forum for "camshaft actuator". I replaced mine after similar issues. I also changed the oil a couple of times within 1000 miles and switched it to synthetic. (I bought mine second hand and have no idea what type of oil the previous owner used). My theory is that the VVT system sticks on and won't let the cam advance to the correct valve timing when the rpms drop so it runs rough and stalls when it returns to idle.
Greg
longmere
03-23-14, 11:38 AM
I have an 07 Escalade EXT with 100K on it. When this started happening, I changed out the crankshaft sensors, no change. I cleaned the throttle body, no change. I changed out the throttle valve sensor and controller, no change. I thought that it might be the ECM getting hot, poured two gallons of cold water over it the next time it acted up, no change. I had a fuel pressure meter hooked up when it stalled, the pressure did not drop down from 60-50 until after it died. The car has been serviced regularly. The dealership that this car was purchased from is of no help. I'm getting disappointed with Cadillac, especially when there have been so many posts on this site with the same problem, and they don't have a solution to fix the problem. I never have any problem with the vehicle stalling around town. It performs perfectly on the open road. It only stalls after getting hot. It was a little bit of a problem when it stalled iin rush hour traffic on the 210 freeway. The only way to keep it from stalling is to keep the rpm's up. Does anyone have any other recommendations?
Punmax
03-24-14, 03:13 AM
My truck experienced the same problem, and it was solved by new plugs/wires, cleaning of the throttle body, and replacing the camshaft actuator.
hcvone
03-24-14, 08:44 AM
Try a few cans of dry gas, you may have some water in the fuel filter that acts up from time to time, sounds strange but we just had this happen to a customer
Cadillac Cust Svc
03-24-14, 12:19 PM
Hi everyone,
It seems like several of you are experiencing similar difficulties with your Escalades. Many of you are giving tips on possible resolutions for the issues and any posts regarding successful fixes are always welcome. If you would like to PM me with your VIN, dealership, and contact information, I can research this issue on my end and document your concerns.
Austin J.
Cadillac Customer Care
ldyoung71
03-25-14, 10:31 AM
I had this problem most of last summer!!!! I have an 07. As everyone states, it is hard to duplicate at the right time for the dealer. My truck also died and would not start. Had it towed to dealer a couple times and couldn't duplicate issue. I have a thread on here somewhere. I had an open invite after a few times to drive it to dealer if/when it acted up again because they wanted to help me fix it. So after driving out of town for an hour to go riding off road vehicles I was trailering, it stalled. I immediately turned around and called my service advisor and said I'm on my way. He told me to come in and he'd have the techs hook fuel gauges and the computer to monitor codes when I got there. They drove around town with me and the trailer hooked up on and alas! It stalled! But there were no codes and no drops in fuel pressure. They were puzzled.... We couldn't figure out why it was doing it. He told me he'd like to research it and try to find out what was going on. I involved Cadillac customer service because my warranty was about to be up.. so while the advisor was researching over the next few days I replaced the camshaft position sensor, throttle body, plugs, wires, air filter, cleaned the maf sensor and none of it did a thing still stalled. I went back to dealer and he handed me a bottle of fuel injector cleaner..or some other type of industrial cleaner to pour in my gas tank (I can't remember the name of it). It was a black can with yellow writing on it. He told me it wasn't something I could buy off the shelf but give it a try run a full tank of gas and then try to tow again. It never happened after that. Oh.. and one other thing. I changed the oil. Sounds weird but one of the posts on here said something about maybe an oil filter being "loose" or something. I have always used mobil 5w30 synthetic as well. Those last two things (oil change / fluid from caddy dealer in tank) have stopped my issue (fingers crossed). It didn't happen the rest of the summer.
hcvone
03-25-14, 11:43 AM
Techron gas treatment is a great product, GM dealership turned me on to it 20 years ago, dump a can every 5k miles
Cadillac Cust Svc
03-25-14, 12:10 PM
Hello ldyoung71,
Thanks for posting your experience within the thread. I am glad to hear that the Customer Care agent and the dealership was able to assist you with this concern and that you havenít experienced this concern since. I hope that your post assists other community members who are experiencing the same concern. Please donít hesitate to reach out to us if you have any further questions or concerns.
Gregory W.
dj_dmorris
04-30-14, 01:06 AM
I have a 2007 Escalade with 117K miles on it and I am experiencing the same problems. My problems started off with the check engine light with a code of P0449 and tight gas cap. I purchased a new gas cap from the auto parts store. That didn’t work. Brought it to the shop and they said it was the emission control system that needed to be replaced. As I waited for the parts to come in I was told I could still operate the vehicle. A few days later the message of Service the Stabilatrack and Service Traction Control before the engine died. For the first 30 minutes it would not turn over. Finally it just started. I was about 75 miles away from home. It made it back home and to the shop without any hiccups. They couldn't find anything wrong. The next day the check engine light came on and I took it to the shop to have the emission control system replaced. After the shop completed the work the light went out and it felt ok. About 4 days later the truck felt like it was lacking power. I took it out of town again and it didn't stall until i returned and came to a complete stop at a light. I was there about 20 to 30 minutes and it started again. I was about 6 miles away from the house. I had to make rolling stops at the stop signs because it felt like it was going to stall out on me. This seems to be an ongoing issue that Cadillac has yet to resolve. Sounds like there should be some type of recall on something being that so many people are experiencing this problem. I don't want to go through replacing everything and spending unnecessary money. Has anyone come up with a resolution to this problem?
cutterman
04-30-14, 08:48 AM
Consider replacing the crankshaft position sensor. When this is failing it will cause random stalling when hot and doesn't always trigger an appropriate DTC. They usually need replacing at some point after 100k miles.
jazzyj76544
06-04-14, 08:41 PM
Same issue with my 07.. only 50000 miles ...the dealer found the same thing said that Greg said.. but before you pay the $1800 change your oil first..."
valve timing when the rpms drop so it runs rough and stalls when it returns to idle."
Greg
Share
kccjescalade
02-19-15, 06:24 PM
NEW POSTER WITH HOT/TOWING STALL PROBLEM. We have an '08 Escalade purchased in Oct. '14 with 111,000 miles and are second owners. Bought it to tow our 4000lb boat with some luxury. Great vehicle BUT have recently encountered stalling when hot and towing our boat 2 times. After each stall event had it towed to a dealer. Could find not fault codes . First dealer replaced the ground battery cable ($300+) due to a claimed high resistance. Thought that might be the problem. Stalled a second time (coolant temp gage at 2:00 position, tranny temp about 215 deg,) hot but not over heated. Had it towed to our local dealer - no problems found and no work performed. Vehicle restarts after cooling for a couple of hours. Apparently camshaft actuator is a major engine front end disassembly to replace - $2600 cost so don't want to just change parts without cause.
I would like to have CADILLAC CUSTOMER SUPPORT reply to this thread so I can submit vehicle details and VIN. This is a major occupant safety issue as this stall could occur during stop & go freeway traffic. High potential for a rear-end collision. We carry our grand kids in the rear seats. Very troublesome situation. Cadillac needs to step up and address this issue before people die. Cadillac - there is a major safety issue here that you must address and solve. Please respond.
Punmax
02-20-15, 04:43 AM
I had mine replaced by my dealer. Most likely the actuator is your problem.
Here's some more info from another thread:
the cam position sensor and actuator magnet is easy to replace
1) REMOVE intake tube
2) remove water pump belt
3 ) remove the belt tensioner on the water pump and the one next to the alternator
4) remove water pump held in with 6 10mm bolts you dont need to take the hoses off the pump i had
room to move it forward
5 ) cam actuator is held in with 3 10mm bolts and cam sensor 1 10mm bolt
the whole process took 1 hour to do
Edit: by the way, Cadillac Support isn't going to do anything for you besides make you an appointment at a dealership near you. Don't waste your time.
kccjescalade
03-28-15, 04:57 PM
Hello Escalade Owners with hot stalling issues,
I would like to hear from those owners that have replaced the camshaft actuator and sensors. This is an expensive replacement so I would like to get a sense
of how likely this is to solve my hot stalling problem. Right now I've no confidence in towing our boat that we will make it. Please reply with your either your
good or n help experience.
Thank you,
KCCJEscalade
clonedzeroes
05-02-15, 08:01 PM
My 2007 Escalade stalls on road trips. The Escalade only stalls when driven for long periods of time.
We were on a trip to California. We exited the freeway and when we came to a light and our Escalade stalled. We called a towing company but by the time the tow truck arrived the escalade started. We thought it might be bad gas or anomaly so we drove to a gas station where the Escalade stalled again. Long story short we made it home and took the Escalade to the dealership. The dealership had the car for two weeks and couldnt figure it out. Eventually they said they found the issue and replaced the camshaft actuator and sensors ($2200). We thought the issue was resolved and two months later we took the Escalade on a trip back to Cali. The Escalade stalled in St George UT. We had the car towed to the dealership. The dealership called and said it was a problem with the engine block or the cylinders. 10 minutes later they said the Escalade started and was running perfect. They had the car most of the day doing 'tests' and couldnt find anything. We headed home and the car made it home and stalled in our driveway. The dealership towed it to there shop where they had the Escalade for 2 weeks and couldnt find anything. I picked up the car. We dont know what to do. We paid a dealership over $2000 for a repair that is not fixed. Two dealerships can not find anything wrong with it. What do you do when you have given a dealership 2K to fix a car and they dont fix it and then they tell you we dont know, there is nothing we can do?
HELP!!!
Any advice is appreciated!!!
Craig
lefx@hotmail.com
love2bhye
07-01-15, 01:39 AM
HELP!!!
Craig
lefx@hotmail.com
I have a 2007 Escalade ESV 101k. and am having the same exact problems. When i got to two o'clock on my temp gauge while towing my 22" sea ray the truck completely stalled out on me on the 710 fwy. I waited 1:20 for the temp gauge to go just under 1/4 and it fired right up. I came home and thought it was a overheat issue of some sort so I replaced temp sending sensor on the block, thermostat,flushed radiator, changed crankshaft position sensor, added a bigger trans cooler and hooked it up to the stock one for 2 coolers for trans fluid. I am out of ideas, can someone with a solution PLEASE HELP!!!!!!!
T
bsgiffor
07-01-15, 11:01 AM
A
Sent from AutoGuide.com Free App (http://www.autoguide.com/mobile)
jmeagher
07-23-15, 02:15 PM
Wow - so many people with the SAME problems and then I never see follow up or resolution.....Someone please chime in - I have nightmares reading these treads because these symptoms are all the same!!!
bignslow
08-12-15, 09:02 PM
I had the same problem with my 07. After towing through the mountains I would get off to get fuel and it would stop running. Only after letting it sit would it start. I took it to a shop and had them look at it. Cleaned the throttle body and mass air sensor. Hit the road and when I stopped for fuel 3 hours later same problem. No codes nothing. Took it to another shop and they tried to duplicate it and nothing. The put there computer on it and got it hot and found that the oil pressure at idle was dropping down to 10 PSI. They changed the filter and oil and the pressure went up to 17 PSI at idle. That solved the problem. I was towing up over mount Shasta and it was almost 100 degrees? The shop thought that maybe running hot and pulling made the oil to thin. It solved my problem and I will always have fresh oil in my vehicle before I tow. I hope this helps
SFX Group
09-28-15, 11:50 PM
+1, stories are no good with out endings....
