: 2013 GT500 Injectors for upgrade?
06-22-13, 04:15 PM
Does anyone know if the 2013 Ford shelby GT 500 injectors would be a direct swap to use as an upgrade to our stock injectors?
06-23-13, 12:05 AM
I run ford racing 60s in my corvette so they might work but how big are they im thinking they too big like 72s
06-23-13, 12:20 AM
I run Ford Racing 73lb injectors in my V. If the GT500 injectors are the same size and I suspect they are, then they will work. Mine are the M9593-LU60 so if you get the dimensions of those and compare to the GT500's you'll have your answer.
The issue is going to be getting the correct injector data.
06-23-13, 12:37 AM
Thanks for the replies. The 2013 injectors are 60s and they can be had for $22 from Tousley Ford. They are the right plug but I worry they're too short.
06-23-13, 06:17 AM
60s that seems very small for 650+hp and a 5.8l
06-23-13, 10:50 AM
Ctsv2 injectors seem small to me too, Guess they just give them enough.
06-26-13, 01:20 PM
the gt500 injectors are too short. you would have to use spacers
06-26-13, 11:41 PM
Thank you Tim, almost ordered 1 to check it out.
