View Full Version : Loose EGR tube
CharBroiled
02-09-05, 10:43 AM
The other day I cleaned out the EGR tubes in my 90 Coupe Deville with a 4.5. One of the EGR tubes was pretty loose, it wobbled and rotated easily. The other was tight (and clogged solid). I didnt mess with the loose one as I was afraid of breaking it off completely. So, how are these things attached? Is it a press fit or something else? At least it wasnt clogged so I didnt have to mess with it.
TwinCreek
02-09-05, 01:23 PM
My 90 Deville has the same situation. Both EGR tubes are loose. I also do not know if this is normal. Can someone tell us?
N0DIH
02-10-05, 02:23 AM
One of mine is also, normal? doubt it, but when it gets warmer they are coming out. I don't like anything loose like that in the intake tract. If it falls in, bye bye 4.9L...
CharBroiled
02-10-05, 05:56 AM
Thats my worry too.. I dont really want a piston and spark plug playing Ping Pong with it..
ja killz
02-10-05, 06:59 AM
what about throwing a small hose clamp on them? it couldnt hurt right?
TwinCreek
02-10-05, 07:51 AM
When I looked at my loose EGR tubes I tried to find a way to remove them but something pins them into place. It dosent look like they will fall out. I dont think a clamp would be good because it might intefer with the air flow in the engine.
DFBonnett
02-10-05, 08:44 AM
Mine are a bit loose, too. Found this...
http://cadillacforums.com/forums/showthread.php?t=22195&highlight=loose+EGR
Seems like it is no big deal.
CharBroiled
02-10-05, 08:51 AM
Ummm .. Doh!
Im usually good with searches but missed that one. If Bbobynski says its OK that thats that :thumbsup:
Thanks DFBonnet :)
BeelzeBob
02-15-05, 02:15 PM
The tubes are staked from the bottom end in the passage that they project into. It is perfectly normal for them to be a bit "loose" feeling. There is no concern over them falling out or anything. Quit worrying about nothing in this case.
BTW....go ahead and clean them out good....loose or not. They do need to be relatively clean and unobstructed.
