View Full Version : My 2005 Escalade parking lights will not come on!
aanncorliss
06-21-13, 09:47 AM
What to do, they are new bulbs too......
Submariner409
06-21-13, 10:48 AM
Moved to the proper Escalade forum.
the cadillac man
06-21-13, 02:15 PM
First check the fuses(if the low beams come on then its not the switch)
Then check the relay in the under hood fuse box(you can swap it around with the horn relay to test it)
If both are good and work then the switch itself may be bad if it is the switch its easy to replace
Best way to check is with the key off so you can hear the relays click(I can hear mine inside the cab when they click)
