: Ipod won't connect through USB
jmarts_cts
06-20-13, 09:13 AM
Normally when I plug my ipod to a power source with the usb cable, it automatically starts charging the unit. When I try it in the car, nothing happens. Am I missing something? Do I have to activate it somehow? Or is it a problem with the car?
Thank you.
hauler
06-20-13, 09:48 AM
If by power source, you mean one of the auxiliary power outlets in the car, into which a USB adapter has been inserted, all that does is provide charging to the iPod. If your music system comes with a USB port, the port may be defective or the connecting cable may be defective.
My wagon's stereo has no USB port. I have a new shuffle with a USB-only connection, and I am unable to find a 3 way cable to allow connection to the auxiliary power outlet and the 3.5mm stereo aux input socket. It's a bummer.
jmarts_cts
06-20-13, 10:41 AM
I'm trying to connect through the USB port in the center armrest console. It can't be the cable because it works with other USB power sources.
al williams
06-20-13, 12:21 PM
I'm assuming this is the first time you have tried to use your iPod in the Caddy. A special cable is required that plugs into your iPod at one end and has two tails, one for the USB port in the console, the other for the 3.5 mm socket in the console. A normal iPod cable won't do the job in this car.
You should have received this cable with the car. I had to go back to the dealer to get mine. The dealer said that they don't leave the cables in the cars because the cables disappear.
hauler
06-20-13, 01:07 PM
In that case, I don't have one either. What does this cable have for a third plug? Flat iPod? 4 ring 3.5mm iPod? USB?
jmarts_cts
06-20-13, 01:54 PM
That would explain why it doesn't work, I was using a regular cable. And yes, it's the first time an ipod is plugged in. I'll contact my dealer. Thank you.
Cadillac Cust Svc
06-20-13, 03:43 PM
Hello jmarts_cts,
I am happy to hear another member was able to provide this information for you. If you have additional concerns or questions after contacting the dealer, please reach out to me!
Laura M.
Cadillac Customer Service
hauler
06-20-13, 03:59 PM
I called my dealer and was told is did not come with the car. I asked to buy one, and they are looking.
So, could you please tell me if your 3 way cable has the flat iPod plug that the old iPods used, or a USB or a 3.5mm plug like my new iPod uses. The cable is $45 from GM.
Citabria
06-20-13, 07:49 PM
Amazon AC Delco 25908035 mp3 and iPod cable. $21.62
Enjoy
hauler
06-20-13, 09:07 PM
Enjoy
That has the 30 pin connector for older iPods. The new one needs a 4 ring 3.5mm or a female USB for the little converter cable that comes with the 4th generation iPod.
Citabria
06-20-13, 10:33 PM
Sorry, I feel like such a dumbass now.
al williams
06-20-13, 10:48 PM
My cable has a flat iPod connector with two cables coming from it-- one with USB one with 3.5 mm. I think it may be the case that what cable you need depends on what radio you have. My radio is Bose and nav. The base radios may use a different cable setup. Your manual may explain what you need.
jmarts_cts
06-21-13, 08:18 AM
Is the sound quality affected if I purchase the cable from the dealer or go on eBay?
jeffc83
06-21-13, 08:52 AM
I purchased mine from eBay and have to start playing the music on the ipod before plugging it into the car, otherwise the sound quality has been fine. If I need to buy another one, I'd get it from amazon.
hauler
06-21-13, 09:22 AM
Sorry, I feel like such a dumbass now.i apologize if I sounded like you should have divined which iPod I had. You actually helped me, since I can tell the dealer that part number won't work for me. Mea culpa.
Citabria
06-21-13, 09:43 AM
No worries,,, I was just trying to be a smart one instead of a dumb one. I also think amazon had adapters too! Anyway good luck. I am still disappointed apple changed things up. All I need is a bunch of different cords.
974705
01-07-17, 10:38 AM
Hello, i cannot connect my iphone 6 or ipod nanos 4 and 5 gen to my 2913 cts coupe. I have the usb aux ipod cable and usb and aux ports in my cnsole with pop up nav. I bought this preowned in dec. dealers are not helpful nor cadillac whike actual owners are saying it should work. Heard everything from it doesn't work, will not support higher than 32 gb devices, to apple doesnt play well with others. I am really disappointed that i cannot make this work. Huge music fan. Not going to use xm, have a karge collection of music. Right now i am slumming it with a plain aux cable with no way to control music but directly on ipod. Not safe. Any solutuions?
The_Judge
01-07-17, 01:43 PM
According to the manual, it does work with iPods, but the car's "Infotainment" system software is ancient, which may be why it won't work with your iPod. There are alternatives that don't involve your iPod:
(1) Copy your music to a USB jump drive or series of jump drives. Leave the jump drive plugged into the car's USB port. Must be a USB 2.0 formatted as FAT32. I believe the max size is 32GB, which is a lot of music.
(2) You can also use the car's HDD, but you're limited to 9GB of music as the rest is reserved for the NAV system. Works a little faster than the alternatives.
(3) And you can record your music in MP3 format on a CD.
chevyfamily
01-18-17, 05:10 PM
I have been going through similar issues and discovered that GM has stopped making part 25908035 and replaced it with a new part 84114049. Problem is the 84114049 isn't compatible with the firmware in our cars. I have been working with a Cadillac Dealer Parts Manager who sold me a replacement 84114049 cable and helped troubleshoot why it wasn't working. I have been in contact with him recently to get an update and was told the following...
"They are not going to reinstate the old number. The updated cable has a redesigned chip in it and firmware/software for the car has to be updated so the new chip will recognize it. Kind of stupid, but isn’t that what engineers are paid to do? Redesign and force people to get new toys…….. So sorry about that, but that’s all the GM engineers have told me. You’d have to have local dealer update the firmware."
Ive asked what to ask for when contacting the dealer regarding a firmware update. I will try and report back if I hear what is needed.
