MWA
02-07-05, 11:47 AM
Review Rating- 99+/ 100
General-
Unit had 40k and two owners when I purchased it from an old line dealer Feb 2003. I put a new Delco battery in it, had the windows tinted, checked the alignment, put new Mich tires on it, had the dealer replace the coolant, transmission fluid, service the injector system, pcv val, fuel filter and purchased a Helm Factory Manual. Change the oil & Delco filter each 3k miles regardless of the oil minder (usually about 40%) and currently have 76k on it
Pros:
It is an automobile, not a car. Unbelievable luxurious ride. It gets about 29 mpg on trips using the cruise control and about 22 mpg on city driving. Never had an automobile literally "tell me what is wrong with it." First thing that I did was find out how to read the DTC's and peridically do this for my records. Unit did not have a factory Delco 12 disc CD changer so I purchased a used one and ordered a bracket and installed it according to shop manual instructions. Absolutely no problems and the Bose system is great. Plan to replace the plugs and wiring @ 100k per manual instructions if not sooner. (if mpg goes down or performance dictates)
The leather interior is exqusite. Everything has been designed to assist the driver and his passengers. I took several days to read the features of this work of art, and still find myself looking back at some wonderful thing that engineers designed for the owners' comfort, east of operation, and maintenance.
Cons:
Someone who did not have a factory manual/and or mechanical experience had been in the left door panel and had broken the fasteners....too bad, because the manual gives step by step instructions that are fool proof on removal of the panel. I designed a few fasteners of my own that securely position that driver door panel. The ashtray has a minor problem- it will not close. Removed it and discovered a broken plastic post that I think that I can repair, too. It is obvious that these are very minor problems and they are what are called "cockpit problems." (a person who does not understand how manuals are to be read before tackling any mechanical repair and goes in roughshod and causes more damage than can be imagined)
I think that the auto has just a few too many sensors, because I get a DTC code that the fuel sensor sees high voltage and a DTC that the sensor on the lumbar horizontal seat is experiencing problems. These both return and I may investigate repairing them, but there are absolutely no other problems to date.
I once was traveling down the road after filling the tank with premium and the green screeen told me to check the fuel cap. Stopped and sure enough, I had not put it on securely. What other cars can keep the driver from mistakes like that??
I salute the engineers, craftsmen, and the manufacturer for building a mighty fine piece of transportation. I hope to put maybe 250k or 300k on it by following the routine maintenance and using high quality fluids. The first Cadillac and only automobile that I have ever owned that does not ever hesitate upon full acceleration.....it is luxury beyond belief.
General-
Pros:
Cons:
