nanardos
02-05-05, 01:13 PM
how / where do you set the fuel mixture (richer / leaner) on a 1968 4 BBL rochester quadrajet carb ?
| View Full Version : quadrajet fuel mixture setting nanardos 02-05-05, 01:13 PM how / where do you set the fuel mixture (richer / leaner) on a 1968 4 BBL rochester quadrajet carb ? davesdeville 02-06-05, 07:07 PM Doesn't sound like you're up to changing jets or metering rods so I'll answer with... a carb shop. cadillacdeville 02-07-05, 01:38 AM there should be a couple of small spring retained screws on the front of the carb I forget which is which but you'll need one of those carb adjustment tools from autozone cadillacmike68 02-16-05, 12:04 PM The screws are only found on 1968-70 models. 71 & up GM capped the screws (I hink you can breeak off the caps) supposdly as an "emissions" bullcrap thing.:annoyed: Katshot 02-16-05, 01:43 PM Yes, that's true. They ARE in the same place but capped off. The caps are removable and then you'll need a special tool to adjust the screws since they have either a "double-D" or "hex" head on the screws. Beyond that everything else is the same as on older carbs. DaveSmed 02-17-05, 01:33 AM Keep in mind these screws adjust the idle circut only. Why do you feel your mixture needs to be changed? I'm more inclined to suspect carb malfunction in most instances...... | |
