: Catera Aftermarket/Performance Options
02-05-05, 12:12 AM
Since there have been so many requests, here are some possible solutions for performance additions and exterior modifications. These are the best we've found so far:
Irmscher- I dont know if they will send to the US. Call them or email them.
Part specification is the same as above. On the side bar, go to Accessories Programme > Omega > Till 1999 (97-99) or From 1999 (2000 -) > Saloon only. Catera is 3.0 V6, Lucas Brakes. Dont select estate/caravan.
Again, not sure on their status on shipping to US.
Go to Tuning > V6 Tuning. Most things should theoretically work except for all of the throttle bodies, and the items for the 2.5 V6 unless it also says 3.0 V6 is compatable as well. For example, the power chamber resonator works on both engines.
Http://www.tirerack.com Various brake applications, tire, suspension.
Http://www.knfilterchargers.com/search/appsearch.aspx - Hi-flow replacement airfilter. Part # 33-2734
http://www.drivewire.com/ - Sparkplug wires (97-98), Intrax lowering springs (must disable rear leveling system!) and camber kits.
Http://www.ultrarev.com/ - Magnacore leads, ignition.
(thanks 97 Catera)
__________________________________________________ _______________
(I am not endorsing use of any of these products. I myself have not tested each item for its compatibility so I cannot guarantee that it will work. Aftermarket accessories may void your warranty or alter the operation of the pollution control systems on your vehicle. Use at your own risk!)
05-15-05, 11:48 AM
maybe try www.regal-shop.co.uk (http://www.regal-shop.co.uk) thats where i buy stuff for my omega the english version i highly recomend the bastuck exhaust systems i fitted one to my car they replace both center sections with a single section and join into one section at the cats and have no silncers at all very loud but sounds so sweet
05-15-05, 12:50 PM
Awesome! Thankyou for the site... there are some nice upgrades on there'. :coolgleam
05-31-05, 01:59 PM
Where can I find headlamp assemblies for 2000 Catera? My left headlamp insides have come loose---they still work, but cannot align correctly...Luis
08-13-05, 01:42 AM
So, if i get one of those exhaust systems it will all fit and work on my 97 3.0 catera
08-29-05, 08:16 PM
If I could only get this kind of dedication from the guys at work, I'd be rich. You've given me some great info over the past year since I bought the Catera Jeffery, Thanks.
(Formerly Catscnfly but switched servs. and couldn't get back in without changing name.)
08-30-05, 11:47 PM
I am just looking for a cool billet or mesh grill for a 97 catera. E&J classics use to make them, but they are discontinued. I like the all black ones that are available in the UK, but if someone knows where I can get one in the USA, it would be appreciated.
09-01-05, 10:08 PM
heres the cheapest one I've found its $219
09-10-05, 12:34 PM
our stock grills go for alot on ebay. I believe I saw a used one go for $250 before.
10-05-05, 01:39 AM
how bout some rims that will fit a 2000 catera sport? i've been kind of hesitant about gettin rims because i wanna go bigger. like 18" or 19" even.:yup: i have the 17" sport alloys now but i'm just not sure if 18's or 19's would fit on my car. if the bolt pattern is 5x110 but it's 18 x 8 will that work? because i know the wheel now is 17 x 7.5..please help :)
10-13-05, 05:30 AM
Hi, i am from the UK, i have the omega which is the same car as the cetera, the correct size for the wheels are 265/35/18 rear and 235/45/18 front the rears are 9" and fronts are 8", if you get the stienmetz i think the rears are10", just make sure you get the correct camber or you will chew your rubber to bits:banghead:
11-22-05, 04:25 AM
i found a cam site http://www.pipercams.co.uk/NewPiperWeb/redesign/05cams/2005%20cam%20cat%20contents1.pdf
they have a cam set that is rated a 30 hp they also have another cam set that dosent have a hp rateing but GUARENTEED ITS MORE POWER:yup: :yup:
