: Stuck Distributor
06-16-13, 10:47 PM
Hey all,
I went to check/adjust my timing today, and the distributor is really frozen (yes, I loosened the retaining bolt).
I soaked it with Liquid Wrench and let it sit. Tapped it with a hammer. Tried wiggling it in any direction with my hands. No dice.
Anyone dealt with thus before? I'm Leary of applying too much force and breaking something.
Sent from AutoGuide.com Free App (http://www.autoguide.com/mobile)
06-18-13, 12:36 PM
If it's that bad you will need to take off the oil pump, then you can bang it out. The oil pump is where the oil filter connects. There is another thread on this.
06-19-13, 03:51 PM
I was afraid someone was going to say that. lol. It will be a few days before I have the time to get into that. In the mean time, I'll keep periodically soaking it with Liquid Wrench and tapping it with a hammer.
06-19-13, 08:05 PM
I feel your pain man! I have the same problem with mine. I gave up and will deal with it another time. Let us know how big an operation it is to bang it out from below.
06-20-13, 12:11 AM
So, I took the air conditioner off and was able to put an oil filter wrench on
the distributor. It took a bit of back and forth, but it came loose. I continued
to spray it with Liquid Wrench and work it back and forth by hand until it moved
The base of the distributor has what looks like pipe wrench marks on it. Tells
me this isn't the first time it's been stuck. Think it's time for a new disty.
06-21-13, 09:14 AM
Does anyone have experience with the conversion to electronic ignition to replace the points?
06-21-13, 02:32 PM
Not directly, but I read a good deal when looking into it. And there are several options.
One option I liked (and may still do) fits inside of your stock distributor, but replaces the points and rotor. Another option, of course, is to get like a 1975 HEI for the engine. The only real caution I've seen there relates to the coil. HEI uses 12V. But with points, a resistor on the coil pulls that down to 6V, otherwise the points would burn up. But I'd probably replace the coil anyway. Another problem I've seen is that the AC belts will be much closer to the [larger] HEI housing.
There is a ton of info online and aftermarket products to make life easier. I just haven't bit the bullet yet.
06-21-13, 02:36 PM
So, I took the distributor out this morning. I can tell just be rotating it with my hand that the bearings are less than good. And there appears to be a wear pattern on the gear. The wear isn't terrible or uneven. But that plus the feel when it rotates don't inspire confidence.
I cleaned it up anyway and set it aside. I covered the hole in the block with masking tape to keep dirt out.
My biggest concern at this point is the wear on that gear. It makes me wonder what the mating gear looks like.
But, I'm out of time for today. So that will have to wait.
