View Full Version : launch control?
StoneCrab
06-16-13, 02:09 PM
Does the CTS-V have launch control? LC was added to the C6 in the last few years and I wonder if it has been added to CTS-V as well. Interestingly, the C6 (any model) never officially had no-lift shift as a feature, although it was effectively there on my 11 Z06. So I wondered if maybe LC is on the CTS-V as an unadvertised feature. In the Z06, you put it in first gear, wheel straight, comp mode on, floor it and the computer revs to about 4000 and holds it there, then release the clutch and shift without lifting the throttle. The TC system modulates throttle based on wheel spin to maximize acceleration.
neuronbob
06-16-13, 02:54 PM
No launch control. I don't even think the tuners have managed a launch control setting on this car in the now six model years of this iteration of the V.
Sorry, the only launch control is your right foot. :(
Jinx
06-16-13, 04:56 PM
Surely V3 will have launch control, but V2 is a 2009 powertrain. I don't think it's gotten any tweaks since introduction except the automatic shift tightening in 2012.
Also, I think only the GrandSport and Z06 got ZR1's launch control hand-me-down; I could be wrong, but I don't think it ever got down to the base Corvette Coupe and Convertible. I remember it being one of the excuses people had for buying the double-fendered car, er, I mean, I remember it being one of the reasons to upgrade to the GrandSport.
Trapspeed
06-16-13, 10:04 PM
They do have no-lift shifting though.
ptrd
06-17-13, 10:44 AM
With most launches on the 1/4 barely launching, is launch control really necessary?
I mean you just barely hold the gas and mash it right?
HUGN*RDS
06-17-13, 02:47 PM
when in neutral, the rev limiter I see when holding the pedal to the floor is not > 6krpm, I think it's more like 3800rpm to 4krpm, could be a little lower.
Dr. Design
06-17-13, 03:24 PM
Actually..... We are getting ready to test our new D3/Race Logic system. We have been developing this for about 3 years now for a seamless integration into the CTS-V platform. If everything tests well, it should be pretty slick once its all said and done.
But yes, for now your right foot is launch control. :highfive:
Thank you,
Dr. Design
D3 Cadillac
shchow
06-17-13, 05:58 PM
I can understand the need for launch control in a clutch-less car because there is no way to modulate the engine speed without moving or screwing up the car by brake torquing.
But I never understood the need for launch control in a car with a clutch.
The clutch is your launch control as long as you know the optimal RPM to achieve minimal wheel spin for take off.
I had this conversation with a Chevy engineer when the Camaro ZL-1 was introduced with LC in manual tranny.
He agreed and pretty much said launch control in a manual car is designed for the novice...
StoneCrab
06-17-13, 08:27 PM
LC is actually fairly impressive. The computer balances throttle with just the right amount of wheel spin to maximize acceleration. A perfect driver could do the same, but it is hard to balance it right on that edge, especially in high HP rear drive cars. LC accounts for tarmac condition and weather. I consider myself a decent driver and I couldn't repeat the same performance so consistently. I found it too easy (and fun) to dip a little too much throttle and get a nice power slide. LC is not traction control in the usual sense. Here is a video I took from my 11 Z06/07 demonstrating launch control with no-lift shift. The pedal is held to the floor as soon as the revs come off idle. LC is disabled as soon as you lift the throttle. You can see the RPMs being modulated in first gear as the wheels are spinning.
https://www.youtube.com/watch?feature=player_detailpage&v=1M5pE8aQ6FY
neuronbob
06-17-13, 09:02 PM
Scared to try no lift shift. :) It's logical to read about, but the motions to do it just seem so unnatural. I'll get there.....
SARDEANIE
06-17-13, 09:08 PM
That's cool as hell!
pat2t2f
06-17-13, 09:45 PM
Try it Bob. You'll love it. It is hard to get used to but it's fun.
RaVeNous
06-17-13, 09:53 PM
I actually find the V2 A6 fairly easy to launch compared to previous car. I'm not sure if its just good tires, the handling setup or both.
No specific launch control though.
Tedboss1
06-18-13, 11:54 AM
Have look at older threads on this topic.
http://www.cadillacforums.com/forums/2009-2013-cadillac-cts-v-general/270810-launch-control.html
Google is your friend.
