View Full Version : Brake fitting size
orandaberg
06-12-13, 10:26 AM
Anyone know the size wrench I need to take the fitting off to remove the brake tubing,this is the hard pipe from front to rear
Thanks
orandaberg
06-12-13, 12:11 PM
9/16"
Thanks
conedoctor
06-12-13, 12:49 PM
Bet it's not, unless we are in 1964 all of a sudden. Did you try a 14mm flare nut wench.
orandaberg
06-12-13, 02:01 PM
yep its 9/16 thats what I needed to remove the fittings, just finished removing the lines both to the rear, the worst of the rust is where the lines fit into the brackets holding the lines together to the frame, however if GM used the right material there would be no rusted lines.
14mm flare nut wrench? Is that a another word for open end wrench? and no 14 mm did not fit
SFVetteman
06-12-13, 03:32 PM
A flare nut wrench is like a 6 point box wrench with a section removed so you can slip it on over the tubing...gives you the grip of the box wrench in situations where you would otherwise have to use an open end wrench.
bill
orandaberg
06-12-13, 04:14 PM
Now thats clever, I will use one to refit, and remove the other 3 needed:(
