: V8 SRX Engine Fan stays on when car is off
06-10-13, 11:40 AM
The other day I noticed that the engine fan stayed on when I turned the car off in the driveway. While it was doing so, the temperature gauge was at about 75%. I'm fairly certain that it is usually dead center. Does that indicate that the coolant is end of life?
06-10-13, 11:47 AM
Coolant life determines its anti corrosive properties not it's cooking efficiency. Check the level is it low? Sounds like a stocky thermostat to me.
06-10-13, 01:30 PM
Where should the temp gauge be?
06-10-13, 01:37 PM
Center is normal. If coolant cap is not holding pressure, could be causing your problem. Some parts stores can check, but only about $5 to replace. If coolant is >4yrs., should replace. You can check w/a DMM. Neg. lead to Batt-, pos lead in coolant, should show about .5V or less if good.
06-10-13, 02:10 PM
If you have V92 you have an extra water pump that from what I could figure out can continue to run after the engine is off so your cooling system keeps working after you shut off.
