: Steering Power Train
Mtneer
06-10-13, 09:07 AM
I recently purchased a 2012 CTS4 Performance Sport Wagon. I have 2 questions.
When transmission is in sport mode I notice it downshirting while I am coasting downhill. Is that normal?
Second, when steering is turned to the lock at slow speeds, engine seems to hesitate and it feels like something is not right. Any ideas? Thanks.
99flhr
06-10-13, 11:08 AM
^ Second question, I`m guessing that by applying more pressure @ full lock you are dead heading the p/s pump, this increases the load for the engine and slows it down. Perhaps easing up on the wheel will solve this problem, certainly won`t turn any tighter because you push the wheel harder. JMO
tinman
06-10-13, 12:06 PM
Whenever I turn my wheel to a (right or left) full lock position I immediately back it off a quarter turn so this load doesn't occur. It is a habit to never keep it fully locked for more that a second at the most.
Sport mode shouldn't just downshift going down a hill. It will do this, however, if you have had it in sportmode and have "hot dogged" it and then backed off and then gone down the hill. Here the trans is merely "getting ready" to engage in more sporting/ready mode for spirited driving (or competition, if-you-will). But if you have merely been driving like your granny and then it downshifts, then that wouldn't be normal.
Tbbt
06-10-13, 02:52 PM
Somebody correct me if I'm wrong (no worry there), but there are 3 different shift patterns in out CTS. Normal = keep it in drive and let the trans seek out the fastest way to get to 6th gear, Sport mode = nudge the shifter to the right and the trans works as normal, but in a more sporty gear change, Manual = nudge the shift lever to the right and then up or down and you are in a manual mode where you have control of the transmission versus the TCM's (transmission control module) choices.
Soooooo..........there are many ways to shift in our CTS cars. Enjoy and choose what gear you like! Your MPG will vary depending on your choices!
Marv
Cadillac Cust Svc
06-10-13, 02:56 PM
Hello Mtneer,
Welcome to the forum and I hope you are enjoying your CTS Sport Wagon! I see other members already provided you with advice of your questions. I am unable to provide any technical advice because I am not a certified technician. If there are questions or concerns you would like to further discuss, I can do my best to help. I can be reached via private message or at socialmedia@gm.com.
Sincerely,
Laura M.
Cadillac Customer Service
tinman
06-10-13, 02:58 PM
You have it correctly, Marv. Standard automatic (D). Sportmode (shows just the gear you are in). And what I call manumatic where you row through the gears and your tach cluster shows both the gear you are in along with a red "M" below the gear you are in.
Mtneer
06-12-13, 08:43 AM
Laura:
I am enjoying my Sport Wagon. I'll have the dealer look at it the next time I'm there.
Cadillac Cust Svc
06-13-13, 08:44 AM
Laura:
Thanks for the update Mtneer. Reach out to us if there is anything you have questions or concerns with in the future.
Sincerely,
Laura M.
Mtneer
06-28-13, 08:10 PM
Took car to dealer today.They gave me a GM bulletin that described my problem perfectly. The bulletin indicated that this was a normal characteristic of car.
Does GM ever issue a fix for these types of things? Dealer also answered some questions and is going to fix a defect. Overall I was happy with experience.
Hello Mtneer,
Sincerely,
Laura M.
Mtneer
06-29-13, 09:51 AM
Cadillac Cust Svc
06-30-13, 02:38 PM
Mtneer,
It's good that you went in - this visit is documented in the dealer's database and can be referred to in the future should anything arise. It's good to hear that it's considered a normal characteristic of the vehicle's operation - do you feel more confident in your CTS after the visit?
These bulletins are developed with our technicians in mind and are aimed at providing up to date service information. They generally will provide a correction to a specific product problem and usually contain repair procedures, information on part numbers and availability, and warranty labor code information. In this instance, the bulletin may have described the condition that has been observed on the particular model of vehicle and states that it is a normal characteristic.
Regards,
Sarah (Assisting Laura)
99flhr
06-30-13, 06:55 PM
Does GM ever issue a fix for these types of things? .
If we are talking about your p/steering issue it`s also a normal characteristic of hydraulic systems in general, hold a control lever on anything till the cylinder reaches it`s mechanical limit (" stroke") You are deadheading the pump. Period.
Mtneer
06-30-13, 07:43 PM
Mtneer
Regards,
Yes, I am more confident. I am pleased with dealer treatment. Thanks.
Cadillac Cust Svc
07-01-13, 03:03 PM
Hi Mtneer,
Glad to hear you are pleased with the dealer treatment. If any other concerns or questions arise, don't hesitate to reach out to us!
Laura M.
