: changing a steering wheel on the 08 STS replacing it with a 2011 sts is that possible
06-07-13, 04:52 PM
So i have a 2008 Cadillac STS. it has the all leather steering wheel, i wanted the wood trim on it so i ran across a 2011 STS wood wrapped steering wheel. if i buy it will i be able to take it to a shop and have it installed without a problem? or does it mecessarily have to be a 2008 STS steering wheel. they look exactly the same so yeah, if someone can let me know i'll be glad! :)
06-07-13, 06:08 PM
Should be fine.
I replaced my 02 Deville DTS wheel with a 04 Deville DHS wheel so that I could add the heated wheel that was a DHS only option.
06-07-13, 06:20 PM
Heated wheel was optional on all 03+ devilles base dts and dhs FYI.
06-07-13, 07:53 PM
I had it on my 04 Dts. What he's saying is that in 2002 you could only get it with the dhs.
Charles Warren
06-08-13, 08:04 AM
i wanted the rear shade in my dts but dhs only. they took away rear vanity mirrors and made dhs only too smh.
06-08-13, 08:27 AM
I'm not sure what the difference is, but the information I was provided is that the 2008 wheel is listed by GM as only for 2008. Again, not sure what's up, but 2009+ are supposedly not the same and have a different part number. Obviously, pre-2008 are definitely different.
06-08-13, 12:07 PM
Since there are some small differences in features, maybe one or more of the wheel-mounted controls uses a different control signal. You may be able to check owners manuals (available online) to see is any controls have moved. It's a pretty expensive thing to buy without knowing. You could offer a try & buy if the seller is willing.
