View Full Version : What is INCLUDED in Performance option? Mine has 18" wheels!???
KXAM
06-07-13, 02:46 PM
Just bought a 2013 ATS which at first we thought was a Premium model. This was a supposed "event car' put together by the dealer. It had 46 miles on it!
Car has 18" wheels and Michllen tires [not supposed to be on a Performance] and the Magnetic Ride Control switch appears to function. On my C6 Corvette if your car does not come with MRC there is no switch for it on the console. The ATS has the switch and the dash panel shows which mode has been selected! The build sheet does not show the MRC or the 18" wheels and tires!?? The car does not have the HUD which I really love in my Corvette! I wish I could add it for a reasonable cost. Am I correct in the above in what a Performance model is supposed to have. The car is my girlfriends, not mine.
SLA
06-07-13, 02:49 PM
All ATSs have the mode selector on the center console regardless if they have the magnetic ride shocks or not.
We're still not all that sure what the mode selector does on non-MRS ATSs.
donavo
06-07-13, 02:50 PM
thats not a premium. HUD and MRC are standard on premium. that sounds like performance. (the mode button and display on the dash for sport mode is on all trims, but depending on trim level it does different things. like for non MRC ones, it stiffens the steering i think and changes the shift points on automatic transmissions to be more aggressive)
KXAM
06-07-13, 03:17 PM
In effect then, it would really only change shift points, or, sharpen them, right!? Very much like a transmission sport mode vs. a less aggressive shift mode. Why would the MRC do that? My guess then is that the MRC switch does absolutely nothing in a non-MRC car even though the dash mode indicator lights up! The 18" wheels then I must conclude are there because the dealer added them for more show purposes. We were not charged for them at any point. Thanks for your replies....
pissedoffwookiee
06-07-13, 03:51 PM
18" wheels are an option on performance
the mode button changes, steering feel/stiffness, transmition program, throttle response, and mag ride, if your car is so equiped.
all ATS have variable steering
all automatic ATS have variable shift logic
all premium have mag ride
thus the mode button does the most for a premium, because it has everything, and the least for any non premium manual transmition car (only steering and throttle are affected by mode in these)
rspitler
06-07-13, 03:52 PM
What is an "MRC Switch"? I have the Premium model and I don't have an MRC Switch. I have a Mode Selector though.
pissedoffwookiee
06-07-13, 04:13 PM
the mode selector is your MRC switch, its an all or nothing affair, sport mode acts on all the varialbe sytems at once
I believe only the CTS-V has a dedicated MRC button, possibly some of the Chevy's (corvette/camaro people please weigh in) the remaining MRC cars tie MRC to the transmition mode to make changes
JSATS
06-07-13, 04:22 PM
Not all premiums have mag ride. My premium is AWD and does not come with mag ride.
pissedoffwookiee
06-07-13, 06:16 PM
My Bad this is true, i forget about AWD living here in SD, then i must also revise what i said earlier, Cadillac also changes the AWD logic in sport mode, they start with a rearward bias, and I believe go even more rearward in sport mode. I will have to research the ATS to get specifics on the AWD and what system it uses and how it behaves. I know that for the XTS it uses a Haldex system developed with Haldex and SAAB and it is a generation newer than Haldex used in some porsches and VW's. the haldex goes as far as 99% rearward bias in some cases, this used to be 100% and still is in the SRX but cadillac discovered that there was some driveline loading/unloading issues in the front at 100% rear power that resulted in a clunking noise when the system would go into and out of 100% rearward bias, so the solution was to dial it down and keep some torque (1%) in the front wheels to maintain loading on those components.
Cadillac Cust Svc
06-08-13, 10:13 PM
Hello KXAM,
If you provided me with your VIN in a private message, I would be happy to look into your RPO codes and tell you which package is on your vehicle. Thank you very much for your time.
Gregory W.
Cadillac Customer Care
z06bigbird
06-09-13, 03:04 AM
Be careful what you wish for.
1. 19 inch tires typically cost as much as $300 to $400 per tire.
2. Don't even ask about the replacement cost of the magnetic shocks after the warranty is over.
3. Word on the street is that the computer module that controls the self parking mechanism on the Lexus cars is about $2500--just for the part.
KXAM
06-09-13, 11:51 AM
Hello KXAM,
Gregory W.
Thanks for all of the input and to you as well George. I found the build sheet and now know what was to be included. What confused me was the MRC function switch operating even though the car does not have MRC! Also, the dealer installed 18" wheels/tires but did not include a portable air compressor and a can of slime when they removed the run flats! I am most happy to have the 18" as I despise run flats. My Corvette C6 came with Goodyear "runcraps" and they did not last 17,000 miles and were loud as hell. So I will go back to the dealer and get them to throw in a compressor and slime kit.
torkibe
06-09-13, 12:16 PM
What "MRC switch" are you referring to?
And I'm not sure what makes you think your tires are not run flats. My tires on my Performance 3.6 are 18" Michelin Run flats, so unless the dealer changed them out for some inexplicable reason, so are yours.
EDIT: There is another set of 18" wheels that are standard on the Performance model, so maybe that is where you are getting confused. The wheels that I have (and probably you) are supposed to only be available on the Premium model. Dealers sometime do things to move cars ;). Either way, they are run flats.
rspitler
06-09-13, 12:36 PM
I too would like to know what an "MRC Switch" is? I have a Premium model that includes MRC, but there is no "Switch".
Cadillac Cust Svc
06-10-13, 08:30 AM
Hello KXAM,
You are welcome. Glad to see others are helping you on the forum. If there are ever additional questions or concerns that arise, don't hesitate to reach out to us!
Sincerely,
Laura M.
MASCAD
06-10-13, 09:18 AM
The switch is just to the rear of the gear selector and to the right of the TCS selector switch. It is labeled ‘Mode” and as other have noted there is not a separate MRC switch. Look at section 9 in your owners manual for additional information.
The 18" machined finish wheels with 225/40 Michelin Run Flats were a option on the Performance model and as you said also on the Premium.(AWD and RWD had different widths) The standard wheel on the performance was 17" with 225/45 Run Flats. I believe only the base model came without Run Flats and therefore had the inflator kit.
huna
06-10-13, 09:51 AM
I think most of the confusion was caused by the original poster calling the mode switch an MRC switch, when it shouldn't be called that at all. It is the mode switch. Therefore, there is no incongruity between having a mode switch and not having MRC.
torkibe
06-10-13, 12:05 PM
There is an ADDITIONAL option of poished aluminum 18" wheels, which is what I have and was referring to, which is only (technically) available on the Premium.
Agreed.
Hoosier Daddy
06-10-13, 12:53 PM
The very heavy polished 18" wheels were factory options on the Luxury and Premium collections.
rspitler
06-10-13, 01:03 PM
[QUOTE="MASCAD"]
I know there is not an "MRC Switch". It's a mode selector. I think the OP should be the one looking at section 9 in Owners Manual
KXAM
06-10-13, 01:13 PM
Thanks guys. Hey, I made a mistake in calling the mode switch the MRC switch. I am a lowly Corvette owner so what do I know about Cadillacs, right!!?? ZR-1 Corvettes have the original form of magnetic ride as well but I only used it when I drag raced my cars.
The dealer installed 18" wheels with Michelin MXM4 ZP tires on our ATS Performance model. I truly dislike run craps so I hope these Michelin ZP's hold up. The OEM Goodyears installed on 'vettes do not!
torkibe
06-10-13, 01:25 PM
I don't think I'd call a 4lb weight difference "very heavy" lol.
I had Goodyear RFT on my BMW, and you're right, they got REALLY LOUD at about 12,000 miles. So much so that people would ask "What is that noise?" BMW actually settled a Class action law suit and helped owners buy new tires depending on how old, how many miles, etc. I PRAY these don't get loud like that.
Correction - I believe they were bridgestone. Loud none the less.
KXAM
06-10-13, 02:50 PM
So, anyone have experience with the Michelin MxM4 ZP run flats?! I would hope they are far better than Goodyears but with a 500 wear rating, man, that is one hard tire..!! My C6 would literally smoke those off in a day or two....can't be much grip with such a hard compound! if they get loud, Cadillac is going to hear some LOUD shouting and feedback from ATS owners! Chevrolet sure did.....
