: I need helpful hints on changing oil on 3.6 STS
BIGGUYRJ
06-05-13, 11:01 PM
Just bought this 05 with only 43K miles, and wish to do the oil change myself, as I always have done. However I am unfamiliar with this vehicle. Is there any special caveats anyone can offer?
For beginners, I see this vehicle uses a cartridge filter, and there is a gasket for the cover, right? Where is it? I haven't been underneath it yet.
I usually use Mobil 1, however I'm considering going to Amsoil premium, 25K or 1 year change interval.
I usually flush the engine on my first change. Any problems doing so on this engine?
dannyquest
06-05-13, 11:11 PM
BIGGUYRJ, The oil filter is a cartridge. Under the hood on the side of the engine driver side. Unscrew the top off & replace the filter. Drain & refill with oil. Danny
EChas3
06-05-13, 11:45 PM
I'd recommend against Mobil1 or anything that isn't recommended. 2005-6 V6 oil should have GM rating GM6094M 5W30. I don't know what you mean by a 'flush'. I'm skeptical.
Mobil1 carries rating GM4718M, perfect for the V8's & later V6's.
MoistCabbage
06-06-13, 12:10 AM
Flushing is for toilets...Don't.
PontiacV8
06-06-13, 05:29 AM
...btw....oil...only a side note...
...this is a sticker you can find in the door opening area on an export (this is a 2006) STS...V6 and V8
...note...there is (also) a 0W40 recommendation...for Europe...
http://i40.tinypic.com/ff8wao.jpg
ddgm
06-06-13, 11:17 AM
QUOTE=EChas3;3456225]I'd recommend against Mobil1 or anything that isn't recommended. 2005-6 V6 oil should have GM rating GM6094M 5W30. I don't know what you mean by a 'flush'. I'm skeptical.
Mobil1 carries rating GM4718M, perfect for the V8's & later V6's.[/QUOTE]
My 2005 STS manual and on the oil fill cap, specifies Mobil 1 5W30 for the 3.6 v6 and 4.6 v8 GM 4718M, no mention of GM6094M . I too would be leary of any flush.
carter's_sts
06-06-13, 03:06 PM
I always use Mobil 1 in my V6 (2006) and it also has that on the filler cap.
PzNuts
06-08-13, 11:35 AM
Mobil1 5W30 here as stated on the oil cap.
No tricks on the change: Pop the cartridge from the top of the engine, open the drain plug, reverse order and drop oil.
There is a rather large socket required to get the cartridge off but you can pick it up anywhere.
Don't know why you would flush the engine that already has 43k on it.
NicholasZ
06-08-13, 01:45 PM
Cadillac STS Owner's manual, section 5-20 and 5-21 state use only GM6094M registered products with viscosity and thickness SAE 5W-30. The only list I found of registered products for GM6094M is at the location below. The list has Mobil 1 5W-30 as a registered product for both GM4718M and GM6094M. Since this list is from Stanford University and not GM themselves, I'd recommend just verifying that the oil container you purchase states it is a GM6094M registered product and is SAE 5W-30. Just in case there are multiple Mobile 1 5W-30 products?
http://pangea.stanford.edu/~schmitt/car/gm_approved_engine_oils.pdf
FYI - Image from STS Owner's manual: 114761
RippyPartsDept
06-08-13, 02:26 PM
GM6094M & GM4718M have both been superseded by Dexos1™
I think 4718 might have superseded 6094
i do know that i have seen some mobil1 bottles that had both 4718 and 6094 on them
either way you will be fine with any of these three GM oil specs (GM6094M, GM4718M, Dexos1™)
there's a grey area when it comes to oils that "meets or exceeds dexos" - like Amsoil - when it comes to warranty issues, but you're out of warranty and your car never called for dexos anyway, just GM6094
also, this is a discussion that's already been had a few times over in other areas of this forum
the short of it is: while technically they're not dexos licensed and tested by GM as such Amsoil will stand behind their product and i doubt the only difference you will notice is in how much it costs vs other dexos oils
on top of all this just stick to the Oil Life Monitor (OLM) and you shouldn't have any oil-related issues
NicholasZ
06-08-13, 03:48 PM
Thanks for the information Chris, I wasn't fully aware of the newer GM Dexos. For anyone that would like additional information, here is one of the more comprehensive web locations I found:
http://www.gmdexos.com/aboutdexos.html
Key information I took away was to use Dexos 1 not Dexos 2, the first is currently designed for gasoline engines and the second for light duty diesel engines.
BIGGUYRJ
06-09-13, 08:47 AM
Thanks 'Nick'. If you follow your thread further you come to the list of Dexos1 certified lubricants:
http://www.gmdexos.com/licensedbrands/dexos1licensedbrands.html
I was pleasantly surprised at how many there are on the list. Including the aforementioned Mobil1. I am also surprised at the location of the filter! Finally it's in an easy place to get to, AND it won't spill oil all over the place! Way to go, Cadillac!
