View Full Version : Engine/transmission mounts
niteryder
06-03-13, 10:18 PM
Have just had a reputable shop inform me that I need to replace the engine/transmission mounts on my '05 SRX (208K miles) It is V8/AWD. There is a slight rumble between 1200-1800 rpm with or without the A/C on. This occurs at rest or in motion. They have ruled out harmonic balancer and other internal issues. Is this diagnosis consistent with the experience of others?
repnatl
06-04-13, 02:36 AM
Put your e brake on left foot on brake wheel blocks if you have them and rapidly press the gas up and down several times while having someone check your engine movement and lift I'd there is a lot of movement or you hear the noise pinpoint which one are bad and replace as necessary
