: 1976 Eldorado brake
jsa03781
06-03-13, 09:17 AM
I have a 76 Eldorado that has two issues I feel. One is the brake noise as you drive down the streets. It sounds like
they are loose and ready to fall off. I have had 2 mechanics look at it and they both said free floating brakes. But it
just is so loud it drives me nuts. The other is the exhaust has been replace but it still sounds like there is no baffling
in the system. It comes off as a rumbling low rider. Any thoughts on this? Thanks
bigm57ict
06-03-13, 10:42 AM
Can you describe the brake noise?
Is it a squealing noise, or more of a rubbing sound? Rattling? Clicking? Thumping?
Can you tell exactly where the exhaust noise is coming from?
You may have an exhaust leak upstream of the muffler.
How much of the exhaust was replaced? Muffler? Headers? Tail pipe?
jsa03781
06-03-13, 06:14 PM
Ok the brakes sound like loose metal jingling around on every crack in the road. They say the brake pads are the culprit. As for the exhaust I replace everything from the manifold back. But not the Headers. But the noise seems to be coming from the back end slash middle of the car. I just think that a car of that calibrator should be a quiet as possible. I would rather see it sneak up on someone they say Hey here I am.
bigm57ict
06-06-13, 09:07 AM
I was hoping someone with more experience with your model would chime in by now.
Here are a couple more questions to help:
Disc brakes or Drum brakes?
Does the noise occur only while braking? Only while not braking? All the time?
If you have drum brakes, I would pull the wheel and drum off and inspect for loose or broken springs.
MrEightball
06-10-13, 08:45 PM
Is it possible that the front noise isn't brakes but one of your CV joints? I had one go and it sounded exactly like rattling metal going down the road. And applying the brakes would affect it as the direction of torque changed. So I thought it was brakes at first. And I couldn't tell by simply looking at the front axles that anything was wrong.
Sent from AutoGuide.com Free App (http://www.autoguide.com/mobile)
70eldo
06-13-13, 07:37 PM
The Eldorado has disk breaks in the front since 1968.
The sound can be anything from something hitting that dust shield in front of the disk (would make a chime sound). Any chance you can have it recorded/filmed while driving?
Does it sound hitting bumbs only or repeatingly with the turning of the wheels?
jsa03781
06-20-13, 09:40 AM
Every bump in the road is what seems to be triggering it. If I happen to be in town or in a parade I keep my foot on the brake just a bit and it is quite then.
70eldo
06-21-13, 08:11 AM
Sounds like something is loose. Better start by checking the break line
MrEightball
06-21-13, 11:20 PM
You should be able to jack up the front, take the wheels off and try moving the pads with a finger or piece of dowel. If they flop around, that's your culprit. But the calipers should have them pretty close to the rotor. If the do flop around, have someone push the brake pedal and make sure both sides move. If you have a frozen caliper, the pad may not be pushed up near the rotor.
If the pads don't move, you may want to look at your tie rods, ball joints or even the rubber bumpers between the frame and front end parts. Look for any wear from metal on metal contact points or play in joints.
jsa03781
06-25-13, 09:30 AM
Thanks
bigm57ict
06-26-13, 11:10 AM
...the noise seems to be coming from the back end slash middle of the car...
I just want to double-check from where the noise is coming. Everyone seems focused on the disc brakes on the front...
I would have someone stand outside the car and listen. The source of sounds can be very decieving when sitting in the driver's seat.
I still think the drum brakes in the rear are the place to look. They have more potential for rattling noises than disc brakes.
MrEightball
07-05-13, 03:06 PM
That is a really good point. Sound "telegraphs" through drivetrain/body parts. I had a rattling in the rear end of my 1999 Jeep Grand Cherokee. But it sounded like it was in the middle in the front while driving.
