View Full Version : what's that noise??
DREZ1992
01-26-05, 02:41 AM
ok when im driving in my 91 sdv i her a sorta kinda rubbing/vibrating noise coming from the driverside wheel well it seems as if the rim is rubbing on the strut of somthing its constent and on-going whether im braking acelerating turning or watever it's there i checked the brakes and the plenty of clearance for everything but when i stick my head out the window like a dog to see where its coming from i cant hear it. anyone had this problem??
danbuc
01-26-05, 03:02 AM
Sounds like a wheel hub bearing. That's sorta what mine sounded like when it went.
DREZ1992
01-26-05, 10:52 PM
i was kinda leaning towards that, i check the price tommorow thanks
toofitt
02-01-05, 05:29 PM
Hi:
If the sound changes pitch when you turn the wheel while driving, it probally is the wheel bearing.
TOM
carnut
02-02-05, 01:30 PM
You are aware of the wear sensors on the inboard brake pad? If the pads are thin, then a rubbing squeal noise will be heard with no brake applied. Reinspect your front pads. Look at the rear pad on the caliper and see if the wear sensor is touching the rotor. Look at a new set of pads to identify the sensor if you do not know what it looks like. Just a guess, but your description sounds like normal wear sensor noise.
DREZ1992
02-04-05, 11:45 AM
pads were fine i change the hub assembly nomore noise thank god, now i hear a different sound from the same area it sounds like somthing is loose. almost like the axle nut aint tight, i retightened the axle nut, and the T60 star bolts around the hub but i still hear it also i check the caliper studs there fine as well.
theres always somthing isn't it.
