: wideband wiring...need help!!
06-02-13, 03:53 AM
For those of you that have a wideband...where did you wire into the power at? I'm assuming you only want power to it when the key is on. So where is the best place to hook into that?
06-02-13, 10:29 AM
If it is low current and only draws a few miliamps just pop off the beauty cover on the drivers side dash there's a green wire that is ignition.
06-02-13, 12:37 PM
Directions say it draws less than 2 amps and power terminal should have 11 to28V DC attatched via a switch or relay when the engine is running.
06-03-13, 12:04 PM
So yes, you can just remove that cover between the door and driver side dash. Use a small panel tool to pull up the side towards you, there's three clips on it then slides towards you. Use a " T-Tap" connect on the green wire there you can also ground it there too! Good luck
06-04-13, 10:41 AM
Cool. Thanks!
