: thinking of going 24's...will they rub?
06-01-13, 11:04 PM
as the post says...contemplating between 22 and 24's ....will the 24's clear turns??
06-02-13, 09:37 PM
I had some slight rubbing when I turned.. all I had to do was drill some holes and pull the fender liner back using zip ties..no more rubbing.
oem 22's for the winter
u2 55 24" for the summer
06-03-13, 07:26 AM
What size tires are u running?
06-03-13, 08:41 PM
thesummer tires are 285/40/24
06-03-13, 10:29 PM
The right wheel offset and back spacing you will be able to tuck and not rub.. Im running a 305/35/24 lowered 2/3 and i was able to do the same thing with drill 2 holes and zip tie the front inner fenders back.. No more rubbing any where after that!
06-04-13, 12:56 AM
Very slight and only at angle at a fairly steep incline. Otherwise just fine. Here's mine tires 305/25/24
http://i56.photobucket.com/albums/g190/grayparatrooper/8ed2f06a-39e0-4324-9f32-10022c4878dc_zps643d03de.jpg (http://s56.photobucket.com/user/grayparatrooper/media/8ed2f06a-39e0-4324-9f32-10022c4878dc_zps643d03de.jpg.html)
06-08-13, 08:49 PM
The only problem i have with my 24's is on the passenger side the black plastic inside the wheel well rubs if im turning REALLY sharp! Other then that i never have a problem, and to be honest, it really isnt a problem, it very rarely rubs and when it does its doing zero damage, not to mention it is not loud at all! ....They rubbed on my Denali ALOT worse! ...The clear my actual bumper completely! :thumbsup: I wouldnt go any smaller then 24! Anything smaller looks to small on these big trucks! :D ....Tires are 305/35/24
