View Full Version : HP expected on a 2.5 upper.
CavemanB52
05-31-13, 06:17 PM
How much HP will be added with a 2.5 upper CAI and a tune?
Stillborn
06-01-13, 02:47 PM
i got 528 rwhp and 536 rwtq. 630hp at the crank is your average with this pkg. (70-90 rwhp is your target)
get an hd 100mm idler pulley and catch-can with said work and be done with it.
CavemanB52
06-01-13, 04:34 PM
Got a dual catch can. And 50mm idler
I asume those are A6 numbers. M6 should be 30-40 hp higher
Houdini
06-02-13, 12:56 PM
Mine put down 555 rwhp while heatsoaked pretty good. Keep in mind that I also had a mild port on the stock TB and snout. Running around 13.6 - 13.9 peak boost.
CavemanB52
06-02-13, 06:59 PM
I had the same in peak boost.
thebigjimsho
06-03-13, 12:39 PM
I was at 10.8 with headers. Not with that pulley, though...
CavemanB52
06-04-13, 12:23 AM
I would like to get it on a dyno. But there isn't one near by. I have to assum mine in also around 550 whp. I want to find a good way to remove heat. Until I get a larger intercooler headers or a meth kit. I'm going to use race gas if/when I go to the track. Daily driving I will keap to mild and and infrequent high boost. Thanks all.
HUGN*RDS
06-04-13, 10:38 AM
Have you seen the super-chiller? I don't work for them, or even have one, but I've read a lot about it and it seems like a pretty good cooling mod. Yes stressing the air conditioner reduces power but there are switches for turning everything on and off so if you daily drive it, no problem.
CavemanB52
06-04-13, 07:16 PM
I was looking a a kit from Snowperformance. Their kit adjusts based off demand.
HUGN*RDS
06-05-13, 08:42 AM
True...but methanol/alchohol injection does produce internal engine deposits over extended periods of time mainly due to the non-ideal atomization of the added fluid. Ever seen the inside combustion chamber of an E-85 engine? I have. Plus you don't want to inject pre-supercharger so that either leaves you needing a blower spacer or another method to inject somewhere in that intake manifold..and make sure it goes into each cylinder equally because you can't measure that without individual exhaust-gas analyzers. just sayin'.
