: HG test and green result
05-31-13, 04:08 PM
Today I check my HG and show green colour.What that mine?On instruction said if yellow is fail,but nothing about green colour.My STS run well,not overheating.
05-31-13, 04:19 PM
Based on that, if it was mine, I wouldn't be worrying about it. It's hard to argue that a correctly working machine is broken! :ill:
Ask any doctor, mechanic, scientist, etc... Test results are NEVER fault-proof positives until they are accompanied by symptoms that support those test results. Never draw conclusions based on a sole piece of data. You have no symptoms whatsoever.
05-31-13, 04:35 PM
Yellow and blue make green
i would say that's a fail
are you overheating?
are you loosing coolant without any external leak?
does your exhaust smell sweet like coolant when you first start the car up in the morning?
05-31-13, 09:38 PM
+1 - If it is currently green, it will most likely test yellow sometime in the near future. If you don't have the money set aside, now would be a good time to start saving!
05-31-13, 10:37 PM
Yup, green is half way between blue and yellow. If it ain't blue, it ain't good.
06-01-13, 10:43 AM
Sorry to hear that. It sucks I know I been there
06-02-13, 08:51 AM
ok,No sweet smell from exhaust,no loosing coolant,no overheating,no codes.
Where and how much is cost for head gasket kit,bolts and etc.What I should buy and replace and never happen again?Price?
06-02-13, 11:37 AM
Wait a minute. You have no HG symptoms, so why did you bother running the test and what are you going through all this expense and work? If it ain't broke, don't fix it. You don't seem to be 100% sure that it's broke. Are you LOOKING for a boogie man?
