: Is it possible to swap 2nd row bucket chairs to bench????
sosatyme72
05-29-13, 09:39 PM
So i just happened to come across a 2nd bench seat that is coming off a '04 ESV. I have a '03 ESV would it be as simple as a
swap to do this?? or is there modifications that need to be done...Im very curious now..
Also I am not the original owner but what comes standard for the 2nd row seating? are captain buckets seats more than
bench or vise versa?
the cadillac man
05-29-13, 11:11 PM
Should just swap out with little issue
mikedyk43
05-29-13, 11:57 PM
The captains chairs can be swapped with the bench without issue, however the seat frames are different from the shorter wheel-based truck and the EXT/ESV models. The longer wheel-based versions have a flat frame while the short version has a step up in the frame to accommodate for the rear wheel well.
sosatyme72
05-30-13, 09:24 AM
ok so as long as i swap from 2 esv models I should be good?
the cadillac man
05-30-13, 10:20 AM
Yep it will work
YoshiMan
05-30-13, 08:10 PM
Ha ha! You don't live in Denver by chance do you? I have the bench and would prefer the Captains chairs!
the cadillac man
05-30-13, 08:54 PM
Me nope
sosatyme72
05-30-13, 09:39 PM
out of curiousity what do 2nd row benches go for?
mikedyk43
05-30-13, 10:16 PM
Usually depends on the condition, but somewhere between $200-$500. I just recently found a bench for mine off Craigslist for $200 in almost new condition.
sosatyme72
07-12-13, 12:21 PM
have a question, my captain seats have heat on them , if i switch to bench do those have heat as well?
the cadillac man
07-12-13, 05:13 PM
Yep the bench seat has heat as well
