: 07 and 08 Key Fobs
zek4964
05-29-13, 04:58 AM
I have a Fob from an 08 sts can I program it for my 07? obviously they look diffrent. I tried to program it tonight but it did not work the DIC said FOB 3? and I put it in the pocket but nothin happened.....
1BadCadSTS
05-29-13, 08:41 AM
Read your owners manual.
1madstsv
05-29-13, 09:01 AM
I was told that 06-07 /08-09 are not programmable with each other but I never tryed it.
1BadCadSTS
05-29-13, 09:16 AM
I have an 08 fob on my 05 sts and fathers 07 sts. Fob works key does not need to custom fit an older style key.
Fierofiend
05-29-13, 10:47 AM
I haven't done this, I have an 08, but found this thread...
http://www.cadillacforums.com/forums/cadillac-sts-forum-2005-through-2012/121398-will-2008-key-fob-work-2006-a-4.html
KingOfLacs
05-29-13, 03:53 PM
I have the new style fob it works perfectly only thing there is a key inside newer fobs and when I had that cut it does not work. think mine is a 09+ cts-v fob.
zek4964
05-30-13, 01:19 AM
Thank you - Fiero. To captian obvious above I did read my owners manual and had no luck. I will try this I see no reason the two diffrent year fobs should not work in an 07 or 08 I just could not get mine to display OFF/ AC ...... I will be sure to try this.
TimmyC
05-30-13, 01:21 AM
I had an 08 fob on my 06 STS and it worked fine.
wiz321654
05-30-13, 01:53 AM
I have a spare fob that I cannot get to program when following the manuals instructions... And ideas? Common mistakes?
Guy.Seminerio
05-30-13, 02:06 AM
Battery definitely good in it?
zek4964
05-31-13, 06:05 AM
I tried again today to add a fob per the vender manual with no luck. I must have to clear all fobs and reprogram with option 3 in the above post. I will try the bat first tho.
Guy.Seminerio
05-31-13, 09:41 AM
Put the battery in question into your known working fob and see if it works.
Cadillac Cust Svc
05-31-13, 12:03 PM
Hello zek4964,
I apologize for the key fob reprogram issue you are experiencing. Please reach out to us via private message if you would like to discuss this concern to see if we can find alternative solutions.
Sincerely,
Laura M.
Cadillac Customer Service
