View Full Version : "Check Washer Fluid" message.
tiranga008
01-22-05, 06:25 PM
I saw this for the first time day before y'day. Filled it up.. seeing again today. Anyone else seen this? Moreover, I see some washer fluid frozen around the front lamps... . a bit surprised.... anyone else faced this? A leak perhaps?
Noreaster
01-22-05, 10:26 PM
I've never seen fluid frozen around the lamps but I park in an insulated garage and use only -40 or better washer fluid. What about you?
syrob@MSN.COM
01-23-05, 12:36 PM
Uh, you mean the washer fluid sprayed on the lens, right ??
Syrob
Noreaster
01-23-05, 01:10 PM
I would suspect a leak - perhaps a fluid supply tube has come loose from a connector near the headlight lens. The weird thing is that you're seeing the frozen stuff on both front lenses - stretches credulity to think that both sides would leak. Unless, of course, your lines up front froze while driving in especially cold weather with inadequate fluid in your tank.
Only thing I can think of.
