: 05 sts stero
idintokic
05-28-13, 10:57 PM
i have a 6disk changer and now it wont let me play my cds at all and it has scratched up all of my cds and i dont know what the problem is anybody have any ideas that can help me out or do i need to change out the whole thing
carter's_sts
05-28-13, 11:04 PM
I don't think anyone really services them. You'll probably have to get a new on.
Guy.Seminerio
05-28-13, 11:31 PM
Yes and before I sold my sts v8 2007 I had an issue with the cd/DVD player as well. The infamous "DVD-x is initializing." I wanted to have it fixed before selling it for my sts-v so i could sell a flawless car. Still have the receipt where the dealer quoted me $2800 to replace it. I said no thanks the next owner will have to do with an iPod.
But maybe something is stuck in there causing it to scratch? My understanding is that the player is sensitive to burnt CDs as opposed to ones you buy. Labels, stickers etc. bad part is whatever you do to attempt to fix it will have to be followed by testing it which may cause more scratched CDs. At one point you say it won't play CDs. Then you say it scratches them up. Can you describe in detail what happens when you put a cd in. Is there any type of error message? Does it give you problems ejecting? Does it make noises? Might not hurt to open it up and take a look inside. May be something obvious. Any more details on what exactly happens might be helpful to others who are trying to diagnose your problem.
idintokic
05-28-13, 11:41 PM
when i put in the CD it takes it in and then it tries to load it up and then u just hear a noise that sounds like it is scratching up the cd and i am using burnt CDS
Guy.Seminerio
05-29-13, 12:19 AM
So it tries to load it, never succeeds but only scratches the hell out of it and continues scratching until you hit eject at which point it immediately obeys the command and ejects? If you don't hit eject it just keeps scratching without giving an error message? After the nightmare with my sts I don't even touch the CD player in my v. Don't want to chance it.
idintokic
05-29-13, 06:43 AM
So any idea what i should do
Guy.Seminerio
05-29-13, 08:35 AM
Well assuming the detail I went into at first there was right, open it up and see if there is any debris in there that is obviously causing the problem. If so get it out and try again. If this doesn't work, or if there is nothing wrong, take it to the dealer, tell them to diagnose, and hopefully the answer isn't to replace the whole system which will cost you almost 3 G'S.
chazglenn3
05-29-13, 09:55 AM
Or buy a good used one on eBay for $150. There was no mention of it being a nav unit. If so, change the cost to about $350.
http://www.ebay.com/itm/05-07-CADILLAC-STS-AM-FM-RADIO-6-DISK-CD-STEREO-AUDIO-PLAYER-P-N-15905317-/181035035458?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2005%7CModel%3ASTS&hash=item2a26876b42&vxp=mtr
http://www.ebay.com/itm/05-07-CADILLAC-STS-AM-FM-CD-Player-DVD-Player-w-Navigation-YQ4-15793847-8134-/390589297136?pt=Motors_Car_Truck_Parts_Accessories&hash=item5af0efb1f0 (http://www.ebay.com/itm/05-07-CADILLAC-STS-AM-FM-RADIO-6-DISK-CD-STEREO-AUDIO-PLAYER-P-N-15905317-/181035035458?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2005%7CModel%3ASTS&hash=item2a26876b42&vxp=mtr)
Guy.Seminerio
05-29-13, 11:40 AM
Yes I am taking about a nav unit good point
EChas3
05-29-13, 10:37 PM
Too bad. I've had our Nav's out and they don't look all that easy to disassemble & reassemble.
Guy.Seminerio
05-29-13, 10:49 PM
idintokic, is it a nav unit? If yes, my course of action is it. If not, see chazglenn3's comment. echas3 says the nav units don't look easy to mess with so if it is a nav unit, and you don't see anything obviously wrong that's causing the issue, you'll probably be out of luck.
EChas3
05-29-13, 11:36 PM
The top slot is only for Nav DVD's. Is there any chance your trouble could be so simple?
Replacing a Nav will require a trip to the dealer to reset security. If you're on good terms, it's a five-minute included service. If you're 'that guy again' who knows.
I don't know if the base radio is also security keyed. A good question. Anyone know?
carter's_sts
05-30-13, 10:51 AM
Boy, wouldn't that be a nice simple fix.
1BadCadSTS
05-30-13, 11:01 AM
All Cadillac radios from 1998+ have theftlock vin encoding.
idintokic
05-30-13, 10:33 PM
its a regular stero no navi unit
carter's_sts
05-30-13, 11:47 PM
Well it won't cost as much to replace at least.
Guy.Seminerio
05-31-13, 08:37 AM
Ok I'm not knowledgeable on that unit at all sorry. But you should still be able to open it up and see if anything like debris is there that could be causing the problem. If not then I'd take it to the dealer.
reneeg
06-02-13, 09:35 AM
2005 sts 6 disc cd changer reading "cd mech error". I disconnected battery cables for 30 min. Didn't reset. Read "cd power error" this was yesterday. Today, reading cd mech error again and won't eject cd's. any suggestions from anyone? Could it be the fuse? I haven't checked that yet
EChas3
06-02-13, 11:01 AM
I don't see how it could be a fuse; it gets power. It's not hard to pull the trim & radio; just be careful not to crack it down low where it's thin. Maybe you can take it apart and look for something obvious. You can't hurt it, it's already broken.
You can likely get a replacement from an auto parts recycler for pretty cheap. It will take a trip to the dealer with proof of purchase to get the theft-lock cleared. If you were considering an upgrade to Nav, now might be the time; but it's imperfect and kinda spendy.
Good luck.
Guy.Seminerio
06-02-13, 12:08 PM
I'm assuming its not the nav one. First link is gen 1 cts users with this issue and possible solutions. 2nd link is detailed instructions on how to take it apart and get your CDs out.
http://www.cadillacforums.com/forums/cadillac-cts-first-generation-forum-2003/74920-cd-mech-problem-now-no-cd.html
http://www.cadillacforums.com/forums/cadillac-cts-forum-2003-through-2007/140362-cds-jammed-player-dismantle-guide.html
And I see you did a search because you found the issue on the srx forums. Saw your post Haha. I'd try that thing where they pull the unit and disconnect and reconnect all the connections.
reneeg
08-25-13, 09:29 AM
Guy, I see a few for good prices on eBay. Mine is non nav. Do u know if I can buy a nav and simply replace mine? Or would I have to change other things like antenna etc?
Subsailor613
08-25-13, 10:34 AM
Are you putting labels on your home burnt CD's ?
Try it without the labels, but, after you LOOK inside
for a foriegn object.
Happy Motoring !
Guy.Seminerio
08-25-13, 10:39 AM
I'm thinking there's more to it than just plugging the nav into a non nav car. Not 100% sure what though.
ddgm
08-25-13, 01:16 PM
There is a thread on here about adding a nav, about 30 pages worth.
http://www.cadillacforums.com/forums/cadillac-sts-forum-2005-through-2012/181473-added-nav-non-nav-sts-100-a.html?highlight=navigation
Doug
jaySTS07
08-29-13, 03:31 AM
I recently swaped out my non Nav stereo with a navigation unit. it was a easy plug and play but had to buy Gps antenna and Nav disc. I purchased a new unit so i did not have to take it to the dealership for any reprogramming.
