View Full Version : 2001 motor in a 1997 catera
97Catera
01-21-05, 08:04 AM
i am thinking about buying a 2001 motor with 44k to swap into my 97 catera if it gives me any problems.Anyone ever do this and have some pointers,are the the same as far as plugs and stuff just pull one out put the other in.I paid 1700 for the car and i love the way the catera looks i just see all the problems the 97-98 have.
Vesicant
01-21-05, 04:01 PM
2001 motor may not work. Since it uses upgraded electronics that uses electronic throttle control as part of the package. Your 97' doesnt have electronic throttle control as well as other updates that the 01 has.
Id go to a Cadillac dealer and see what recall work was done.. if the camshaft/waterpump tensioner system has been replaced via recall, it should be fine (if it even needs it), secondly the oil cooler should be replaced if it hasnt under recall. Those are the two major ones that will kill any catera.
97Catera
01-21-05, 05:46 PM
so the camshaft/water pump tensioner and oil cooler are covered under the recalls if it hasnt been done already.thanks again jeff i have only been a member of this forum a few days and already everyone has been helping me so much
Vesicant
01-21-05, 05:59 PM
wait, the oil cooler isnt technically recalled but should show up as being repaired if by Cadillac which it should be ... sorry for the mis-info. There js a new version of the oil cooler in use now. And also, valve covers and valve cover gaskets can be a problem as well.
97Catera
01-21-05, 07:04 PM
so i need to buy new valve covers and gaskets.
Vesicant
01-21-05, 08:53 PM
No, im just saying they can be ... any engine. Just so you know that was one of the problems but this one cant really be prevented unless you say replace them everytime.
97Catera
01-22-05, 10:02 AM
is there any way to switch the 2001 motor from electronic throttle to cable .sorry for all the questions just figured they were interchangable because the junkyard said they were.
97Catera
01-22-05, 11:44 AM
i called the dealer and gave the vin # and they said all recalls were completed not sure if they are lying my vin is w06vr52r3vr079110 1997 catera if someone else can check on it for me to make sure.
Vesicant
01-22-05, 11:49 AM
There shouldnt be a need to switch engines now... if the Cadillac dealer said all recall work was done. Go to the dealer directly and have them show you what they see.
97Catera
01-22-05, 04:38 PM
ok sounds good jeff thanks for the help.one more thing i put a brand new battery in thursday morning and today i went outside to start it and the battery was dead,i had lights and stuff just wouldn't crank.Maybe a defective battery?good thing it has a 2yr warranty
