Hey could use some help locating the ecm and tcm module I heard the ecm is in front of driver side wheel and tcm next to the fuse box under hood. Is this them can anyone confirm please?
Thanks and Happy Memorial Day everyone!
Ok thanks. I'm buying both modules from madtuner so the ecm which one do i replace since there are 3 plugs there? I dont really want to be pulling plugs until i got the chips and ready to install.
Basically this is how I understand the process to be:
1. You swap out the entire modules with what he sent you with the new tune already flashed depending on what you ordered from him.
-or-
2. You plug in a cable to the ODB port and connect to your computer and flash the file(s) he sent you to your existing hardware without removing anything.
So how is he sending me these files that i plug into the obd port? I linked the two things I purchased. Sorta lost on what I am getting/what I do and so on.
1BadCadSTS or MadTuner would need to confirm this but I believe you will get the cable, some software, and the files to flash to your car.
You will load that up on a Windows Based laptop and connect to the car's ODB port and flash the components directly through the car's system as if you were GM flashing an update to the module via the Tech II or similar device.
You won't have to remove any components from the car with this method.
I would go for a drive. Park, use his software to pull a backup of the stock tune (assuming it can do so). Then Flash according to his instructions, then go for another drive to see the changes.
If you really wonder flash stock back to the car and drive again. Perhaps do just ECM first then TCM, then both, this would show how each behaves. Be sure to drive in all 3 modes to see how they have changed (auto/sport/manual).
AHHHHHH THANK YOU sooo much. Yeah now that you broke it down I totally understand what I'm going to have to do. Thank you so much will report back with results
Correct. You leave a deposit for the cable which is refunded upon return (I kept mine) and you load a program he provides you with and you flash the modules while they remain plugged into your car. Or you ship him your modules and he will ship back tuned ones.
TCM: shift delay removed in auto stick move shift points higher up in band removed torque management increased shift pressure firmness 10% in auto 20% sport 25% in manual etc etc.
These are all by choice and mad tuner makes the tune for you.
ECM: adjusted knock retard and tuned for premium fuel to increase roughly 15 hp and 15 tq
I spent more on my corsa and volant and all they added was eye candy and noise. Mad tuners adjustments gave noticeable improvements.
I second that, noticeable improvements!!!!!! I didn't get any hp increases but the TCM adjustments makes my car feel stronger, I use to avg 75-80mph now im hovering around 90-95 it holds third gear longer and speed climbs quick, before the tune when the car got to third gear the power would drop and then catch up but now there is no drop 1,2,3, I punch it and i'am gone lol!!! in my chester cheetah voice (well worth it)
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
