I want to put a aftermarket touch screen in my car... Will that replace my driver settings controls and will I still be able to change my driver/car settings?
I've read that referenced thread a number of times and it's great. That procedure has stood the test of time. Do we still face the same challenges in 2013 with loosing driver's personal settings if we switch to an aftermarket system? I'm just curious since I see all of these adapters and wiring kits that allow you to retain original factory controls and settings. So outside of driver personal settings are there any other functions that you loose by going aftermarket?
Thanks again. So much for simplicity. Is the procedure as much involved as polar bear's adding navi to non navi? I was originally wanting navi but would settle for at least satellite. But looks like 6 disc changer is where I may end up. Can I even add a sub to my non nav 8 speaker Bose system?
The XM modules are vin locked and cannot be reflashed you'd have to order a new one with the vin of a car that has one and have the dealer program it with your vin.
There may be after-market add-in modules available for the base radio if you're just after XM, Bluetooth audio or a line-in. The OEM Nav is a long-way around to get that. While it may be the easiest way to get Nav, full functionality may not be a practical (cost effective) goal. Members advising trading for another STS to get desired features are making a valid point.
I'd say the way to start is to be sure what's most important to you and then evaluate the alternatives. Unfortunately, the STS wasn't sold/produced in large enough numbers for a lot of aftermarket solutions but members have found several. If all you want is XM, there are several ways to get there: (it was available on base & nav OEM's and then aftermatket options). If your heart is set on a full-blown system, I remember reading a post from a member who found a module that would let him store the base car settings without keeping the radio. (That may not help owners that want to replace their OEM nav but it solves that concern for you.)
There is also the matter of the xm aerial which I believe is in the shark fin, which may or may not be there. I'm guessing not. The shark fin also houses the Onstar aerial.
Agreed. If the XM antenna isn't there, it's no small task.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
