View Full Version : What does your speaker look like?
ImEpayne
05-24-13, 12:52 PM
The previous owner of my '06 V had his own stereo system in the car. I noticed I have no bass with the stock speakers. I finally went back and checked to see if I have a stock sub woofer. There is one. But the stock wiring is not there. I was hoping someone could look at their stock sub back there and tell me what I'm missing and where I might be able to trace down that stock speaker wire.
Here is what mine looks like...
I don't want to have to have a separate sub and amp back there just to get a little bass.
I know the stock amp is back there as well... would it be relatively easy if all my stock wiring is gone, to run some speaker wire from that stock amp to the sub?
Thanks
NC-V
05-24-13, 02:25 PM
That is the factory sub, or a stock replacement. The little box is a LOC which allows you to hook up an aftermarket amp, so the previous owner had an aftermarket amp and sub setup back there. The two wires (black with colored tracers) that are hooked up to that LOC should plug right back onto the the sub, unless they cut the ends off to splice the LOC in.
ImEpayne
05-24-13, 03:26 PM
Spot on. Thank you very much. That box was spliced into the original speaker wires. Took it out and they plugged right back into the stock sub. Works like a charm now. Thanks for the easy fix.
What a difference having a bit of bass!
