: Almost ready to start modding!
sammyboy
05-24-13, 11:30 AM
I have wanted a v since the first time I saw one. Finally I purchased an 04 a few weeks back. It is black on black and stock with the exception of a cone filter that someone just stuck in place of the airbox. So far I have ordered, with with some help and countless hours of reading the forums this is what I have or have ordered.
-H&r springs
-MM spacers
-Pissnuoff shifter
-shifter bushings
-everything available from revshift (minus the flex coulper)
-Pacesetter headers
-x pipe, cutouts, mufflers
-tires 245/275
I will keep you guys updated as parts arrive and when I get around to installing them.
I have questions about the following though.
-Rear end
Should I buy a gen four from the dealer and do gforce axles? Or just save a little more and do a 8.8 swap? I can swing 2000 for the axles and diff if it will last for awhile but cant afford 6k.
-Driveshaft
Should i buy a one piece? my carrier bearing I think is junk I have not been under the car to closely examine it.
-cai intake
Should I just buy a stocker used? Is there an aftermarket that really gains?
-Heads/Cam
I have a torquer v2 because I took it out of my wifes truck. I just wasnt happy with it's performance. So should I go with a sns from tick I just want a off the shelf head/cam combo that works. If that is possible.
Clutch
LS7 or a twin disc what do you think?
-Transmission
Would it be benifical to have tick or someplace else rebuild it? it grinds alittle into second but I have old nasty clutch fluid that may be causing that.
Keep in mind this is going to be my dd I sold my 2 door go cart for this (going to start having little ones). It has to be reliable I am a fairly easy driver used to having to launch my cars soft I may track it but not hard.
By all means if I am misguided in anyway put me back on track.
Thanks
Sam :suspense:
QwkRhino
05-24-13, 12:57 PM
Quick tip the SRX diff also works in our cars and seem to be a lot cheaper and stronger then 1st & 2nd gen diffs. If you get this part # 19178781 GT4 G80 3.73 option and limited slip. You would just have to cut off about a inch off the pinion shaft and swap out the pinion input coupler with your old diff. I'm seeing them on ebay for about $500 brand new.
RyRidesMotoX
05-24-13, 01:21 PM
Get new axles and see if that helps with wheel hop. I was tracking the car around a tight road course and didn't get any hop. It was sliding all over the place, wet and dry. I do get wheel hop in a straight line though. And that is what kills the diffs. New axles will help a lot from what I understand. I'm going to be getting some geforce anti hop axles to see if that will help. I'll probably do them when I do my heads/cam at the end of next year.
alradco
05-24-13, 01:51 PM
Looks like a nice list of mods. Would get a tune as well.
sammyboy
05-24-13, 04:02 PM
I forgot to mention I tune myself so that slipped my mind for the list. I called gforce and they told me if I plan any amount of power the axles are really no help but just was wondering if anyone here knew or thought otherwise
philistine
05-24-13, 04:46 PM
Which 2 door?
sammyboy
05-24-13, 06:15 PM
2010 cobalt ss/tc it was fun while it lasted it was 350whp 440wtq. Wife said car seat I said cts v or tbss. Got the v.... first.
http://i1343.photobucket.com/albums/o789/smcclead/2011-06-27_124752.jpg
I don't know how to post pics yet but here is a link.
RyRidesMotoX
05-24-13, 07:00 PM
I had a cobalt SS/TC also. I loved that thing. 440wtq is e85/91 mix right there. I got there on a stock turbo running 26psi with a Treadstone stage3 kit and a tr8 intercooler.
They seem to help quite a few guys, just don't do huge burnouts. The axles will go into any rear end you want as long as the splines match.
sammyboy
05-24-13, 08:37 PM
I just had e85 an aggressive tune and cat less down pipe. It was a blast to drive and got great mileage. I absolutely loved messing around from a roll with just about anything most people would at least give me a thumbs up.
If you had a modded tc then you know how to be easy on the skinny pedal. Huge smoky burnouts are cool but having a driving car is better.
I just had e85 an aggressive tune and cat less down pipe. It was a blast to drive and got great mileage. I absolutely loved messing around from a roll with just about anything most people would at least give me a thumbs up. If you had a modded tc then you know how to be easy on the skinny pedal. Huge smoky burnouts are cool but having a driving car is better.
RyRidesMotoX
05-25-13, 05:01 PM
Yea I loved my TC but me and my fiancee had a kid last year so I needed something with 4 doors... You know how those back seats were in the TC. I remember doing a roll race with a Roush Stage 3 supercharged mustang... I was door to door with him the whole way on my 91 grocery getter tune. If I was on ethanol I would have walked him easy. She had about 370lbs ft at the wheels on my 91 tune. On my ethanol mix I had more like 420-430 lbs ft. I had an Exedy clutch in it along with TTR stop mounts. Ah memories I loved that thing. There are some videos of AAA Speedway in Fontana on my youtube account. I had a few guys come up and ask what I had done to it to make it so quick.
https://www.youtube.com/watch?v=TWkYLhv7G5I&feature=youtube_gdata_player
DMM
05-25-13, 05:19 PM
The OE CV joints and rear diff handle approximately the same power, so axles don't help all too much unless you don't plan on getting into any fun until the top of second. I had a GEN IV rear and stock axles and was lucky nothing ever broke, bu upgraded to the 8.8" for peace of mind. The 8.8" takes care of many weaknesses at once so it is well worth the investment.
sammyboy
08-09-13, 11:26 AM
ok got all the parts installed with the exception of the shifter that I am still waiting on. But I do need a drive shaft I have looked at the options avalible but I am still unsure of what to get. My carrier bearing is junk so what do you guy think. I got a gen 4 diff installed while I was at it so that should last a little while.
OH and my car feels completely different now it is amazing.
PISNUOFF
08-09-13, 01:50 PM
Your shifter will be on your doorstep tomorrow. I shipped it yesterday. Sorry for the wait.
MotorMounts
08-09-13, 02:00 PM
Rear end
Who's selling an 8.8 kit for 6k ? Is there a new 8.8 vendor that I'm unaware of ? Anyway..... Our 8.8 turn-key kit with two piece drive shaft or one piece aluminum drive shaft (your choice or one piece carbon fiber +$300) is $4500 +$200 for shipping. Add $375 for the upgraded 4340 outer CV's. That's $5075 with the CV's, turn-key on your door step. Installation of the whole kit can be a DIY for most people in 8 hours.
sammyboy
08-09-13, 04:27 PM
Rear end
Sorry 5k I may have been thinking 9 inch when I said 6k. I already did the gen 4 diff no axles but I hope it will hold together for a while. One question I do have though is if I went with a stock length drive shaft could it later be modified to fit a 8.8 or would I have to sell it and buy new?
No problem man I just got the bushing the other day from luke not sweating it one bit the trans mount worked wonders for shifting but still very looking forward to feeling the difference.
MotorMounts
08-09-13, 04:56 PM
Sorry 5k I may have been thinking 9 inch when I said 6k. I already did the gen 4 diff no axles but I hope it will hold together for a while. One question I do have though is if I went with a stock length drive shaft could it later be modified to fit a 8.8 or would I have to sell it and buy new?[COLOR="Silver"]
Yes, it could be modified (shortened) to fit the 8.8. I would get it from Drive Shaft Shop in order to make the life easier, now and when you're ready to modify.
