: black box under car????
cart69
01-18-05, 09:49 AM
over the weekend i was under the car changing the oil and looking at my ride control pump assembly and noticed in the back of the car on the drivers side the is a black box up in the quarter panel its looks like it has fuel lines running to it 2 are the regular size and it has one small line that goes to it, the small line was ripped off and looks lke it is dry rotted anyone know what this box is and whats its for also what is the small line for thats not hooked up for i plan to fix when i can get some new hose for it but never seen anything like it before, also man that ride control assembly is a pain to get to!!
danbuc
01-18-05, 12:54 PM
It could be a control module for your rear air shocks maybe? :confused:
turbojimmy
01-18-05, 01:44 PM
That's the EVAP canister. The 2 big lines go to the fuel tank and a fresh air valve. The smaller line runs to the purge solenoid under the hood (by the throttle body). If that smaller line is broken, you should be getting an P0440 error because the engine can't draw a vacuum on the system.
Jim
cart69
01-18-05, 02:21 PM
i dotn recall seeing a 440 code but it looks like the hose is melted shut. it looks like normal vacuum hose line i will inspect it and replace the section thats gone or the whole thing depending on what the rest looks like, do you think this would effect anything else, gas mileage? etc??
turbojimmy
01-18-05, 02:32 PM
If it's melted shut and not leaking then I think the PCM would get what it's looking for (vacuum) - hence no code. 1996 and up models have a more sophisticated EVAP system and can detect blockage as well by operating the fresh air solenoid valve. Your blockage won't affect fuel economy or even emissions for that matter. The system captures fumes from the gas tank in the EVAP canister and routes them into the intake tract for combustion via the purge valve. If it ain't broke (no codes) don't fix it.
Jim
