davesdeville
01-18-05, 12:08 AM
I've had my 75 Deville for about a year now. It's definately the most comfortable car I've ever sat in. The ride is absolutely terrific, it glides over speed bumps and I can hardly notice them. Sitting on a 130" wheelbase, the car is 231" long and 80" wide, longer than most full size trucks and wider than an Hummer H2.
The 500 cubic inch V8 provides adequate power in stock form fed through a TH400 3 speed automatic, stock 1/4 mile times were around 18 which wasn't too bad for a full size in the 70s. Expect about 8-10mpg city, up to 14 cruising at 65 on the highway. The 500 was rated at 190hp and 380 ft.lbs. of torque, however for some reason they were underrated and actually put out 300hp and nearly 500 ft.lbs when rebuilt to stock specs. For a little more oomph to get the 5049 pound sedan moving there are many performance parts available, anywhere up to 600hp can be done for fairly cheap and more for more money.
Maintaining this car is pretty easy, it seems like there's plenty of room everywhere, and the engine compartment is absolutely gargantuan - it can be hard to reach the engine without climbing up inside under the hood. Being a GM and being from the 70s, there's no computer and parts are cheap.
Pros: Extreme comfort, size, safety, reliability, pimp factor, ride, performance parts availability.
Cons: Gas mileage, handling (like you'd buy one of these for handling.)
